14 years ago
Programming Cyclone III (EP3C16Q240C8N) on ARM board
Hi
My interest is to know if someone have try to install Quartus II programmer on a ARM linux and if it worked?
My second interest is to see the source code that do that. I have not see the source code of Quartus II Programmer, is it available?
My last question is if anybody have any suggestion of open source project that could do the programmation of cyclone III using USB blaster or JTAG?
Kevyn-Alexandre
    I'm not sure what source you are referring to (i.e., where the jbistub.c source code comes from), but if you are looking at a port that uses the parallel port, you have to realize that the 'classic' parallel port is output only at the DATA registers, and then input is obtained from either the CONTROL or STATUS registers. Those registers need to have their output drivers disabled by basically writing 1's to the port, so that an external signal can drive the pin low. Hence a line like:
    write(com_port, &ch_data, 1);
    to port 1 could simple be deasserting the contol lines so that the TDO signal can be read.
    Just a guess ...
    Cheers,
    Dave
    --- Quote Start ---
    --- Quote End ---
    So I'm using JAM STAPL from there:
    http://www.altera.com/support/devices/tools/jam/tls-jam.html
    The source code from there:
    https://www.altera.com/download/legacy/jam/dnl-byte_code_player.jsp
    unzip the exe you will found the file that I was speaking about (jbistub.c)
    From source line 244 you can see what I was speaking about.
    --- Quote Start ---
    Just a guess ...
    Cheers,
    Dave
    --- Quote End ---
    So this 0x7e will be a parallel port specific thing! I will make some test with or without to see.
    thx
    kap
    --- Quote Start ---
    --- Quote End ---
    Its not parallel port related. The code shows its clearly related to serial port communications.
    What the codes mean is related to the protocol the serial device uses. For example, elsewhere you will find code like:
    data = 0x70; write(com_port, &data, 1); /* TDO echo off */
    data = 0x72; write(com_port, &data, 1); /* auto LEDs off */
    data = 0x74; write(com_port, &data, 1); /* ERROR LED off */
    data = 0x76; write(com_port, &data, 1); /* DONE LED off */
    data = 0x60; write(com_port, &data, 1); /* signals low */
    Unless you own whatever serial device they are communicating with, just ignore that code.
    I haven't looked at the "byte code" player, just the jam player ...
    https://www.altera.com/download/legacy/jam/dnl-player.jsp
    Cheers,
    Dave
    --- Quote Start ---
    --- Quote End ---
    Thx for the clarification. The fact that they have put comments on all of them and not on the 0x7E made me doubt.
    --- Quote Start ---
    Cheers,
    Dave
    --- Quote End ---
    mmm I have used byte code player since this what they were explaining in:
    http://www.altera.com/support/devices/tools/jam/tls-jam.html?gsa_pos=2&wt.oss_r=1&wt.oss=jam%20stapl
    Section Related Documents:
    Using Jam STAPL for ISP via an Embedded Processor (PDF) chapter of the MAX II Handbook
    So a quick difference between file of each is that the JAM Player have more files then byte code player:
    tree jbi_22/code/
    jbi_22/code/
    ├── JBICOMP.C
    ├── JBICOMP.H
    ├── JBIEXPRT.H
    ├── JBIJTAG.C
    ├── JBIJTAG.H
    ├── JBIMAIN.C
    ├── jbiport.h
    └── JBISTUB.C
    0 directories, 8 files
    tree jp_25/source/
    jp_25/source/
    ├── JAMARRAY.C
    ├── JAMARRAY.H
    ├── jamcomp.c
    ├── jamcomp.h
    ├── JAMCRC.C
    ├── JAMDEFS.H
    ├── JAMEXEC.C
    ├── JAMEXEC.H
    ├── JAMEXP.C
    ├── JAMEXP.H
    ├── jamexprt.h
    ├── JAMHEAP.C
    ├── JAMHEAP.H
    ├── jamjtag.c
    ├── jamjtag.h
    ├── JAMNOTE.C
    ├── jamport.h
    ├── JAMSTACK.C
    ├── JAMSTACK.H
    ├── jamstub.c
    ├── JAMSYM.C
    ├── JAMSYM.H
    ├── JAMUTIL.C
    ├── JAMUTIL.H
    ├── JAMYTAB.H
    └── makefile.mak
    So what I'm seeing from the diff of these files are the same files with add-on. I will use the JAM PLAYER to benefit from the add-on.
    thx
    Kevyn-Alexandre
