15 years agoProgramming Cyclone III (EP3C16Q240C8N) on ARM board
Hi My interest is to know if someone have try to install Quartus II programmer on a ARM linux and if it worked? My second interest is to see the source code that do that. I have not see th...
15 years ago --- Quote Start --- So this 0x7e will be a parallel port specific thing! --- Quote End --- Its not parallel port related. The code shows its clearly related to serial port communications. What the codes mean is related to the protocol the serial device uses. For example, elsewhere you will find code like:
data = 0x70; write(com_port, &data, 1); /* TDO echo off */
data = 0x72; write(com_port, &data, 1); /* auto LEDs off */
data = 0x74; write(com_port, &data, 1); /* ERROR LED off */
data = 0x76; write(com_port, &data, 1); /* DONE LED off */
data = 0x60; write(com_port, &data, 1); /* signals low */
Unless you own whatever serial device they are communicating with, just ignore that code. I haven't looked at the "byte code" player, just the jam player ... https://www.altera.com/download/legacy/jam/dnl-player.jsp Cheers, Dave
