Processor interface to transceiver PHY
I have been looking into the design process for implementing a (Optical) transceiver interface in within a Intel FPGAs. How / where does the processor (e.g. Nios) that is to be responsible for the transfer of the applicable data meant to interface to the PHY ? Where can I find information about this interface ?
- aikeu
Hi SDavi9,
Aik Eu
- aikeu
- SDavi9
Dear Aik Eu,
Thank you for your response !
The first reference I have already seen - however this seems to be only a loop back and doesn't give me any details how I would connect and use a NIOS processor with it ? I need to know how to transfer data from the NIOS out of the FPGA via the optical interface ???
The 2nd design also appears to be a loop back design and I don't see where the NIOS would be connected. Also it appears to be a SDI design and not a Optical interface ?
Best regards
Shmuel
- aikeu
- SDavi9
Dear Aik Eu,
We have a number of designs implemented with a NIOS II processor and TSE. What we need is an actual design example that implements an interface to the Cyclone 10 Gx development board transceivers via the FMC connectors AND that can be used with a NIOS processor to send and receive data ?
Best regards
Shmuel
