15 years ago
problems on my thesis
Heyy I'm doing my thesis on tetris game simulation on fpga and not good at vhdl that much. Your asist would be great. At first, i need to make the code below work. It's just the beginning of VGA code.
I'm using DE0 board (the reason of may problems I think), Quartus II and vhdl.
I had to change VGA_CLK, VGA_BLANK, VGA_SYNC as a comment cause they dont exist in DE0's pin assignment list.
the problems are these.
warning (10631): vhdl process statement warning at vga.vhd(102): inferring latch(es) for signal or variable "vga_hblank", which holds its previous value in one or more paths through the process
warning: output pins are stuck at vcc or gnd
warning (13410): pin "vga_hs" is stuck at gnd
warning (13410): pin "vga_vs" is stuck at gnd
warning (13410): pin "vga_r[0]" is stuck at gnd
warning (13410): pin "vga_r[1]" is stuck at gnd
warning (13410): pin "vga_r[2]" is stuck at gnd
warning (13410): pin "vga_r[3]" is stuck at gnd
warning (13410): pin "vga_g[0]" is stuck at gnd
warning (13410): pin "vga_g[1]" is stuck at gnd
warning (13410): pin "vga_g[2]" is stuck at gnd
warning (13410): pin "vga_g[3]" is stuck at gnd
warning (13410): pin "vga_b[0]" is stuck at gnd
warning (13410): pin "vga_b[1]" is stuck at gnd
warning (13410): pin "vga_b[2]" is stuck at gnd
warning (13410): pin "vga_b[3]" is stuck at gnd
warning: design contains 2 input pin(s) that do not drive logic
warning (15610): no output dependent on input pin "reset"
warning (15610): no output dependent on input pin "clk_default"
pin assignment
ok vga_b[3] location pin_k18 yes
ok vga_b[1] location pin_k21 yes
ok vga_b[2] location pin_j22 yes
ok vga_b[0] location pin_k22 yes
ok vga_g[3] location pin_j21 yes
ok vga_g[2] location pin_k17 yes
ok vga_g[1] location pin_j17 yes
ok vga_g[0] location pin_h22 yes
ok vga_hs location pin_l21 yes
ok vga_r[3] location pin_h21 yes
ok vga_r[2] location pin_h20 yes
ok vga_r[1] location pin_h17 yes
ok vga_r[0] location pin_h19 yes
ok vga_vs location pin_l22 yes
ok reset location pin_j6 yes
ok clk_default location pin_g21 yes
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity vga is
	port (
		reset : in std_logic;
		clk_default : in std_logic; --default is 50 MHz
--		VGA_CLK, --Dot clock to DAC
--		VGA_BLANK, --Active-Low DAC blanking control
--		VGA_SYNC, --Active-Low DAC Sync on Green
		VGA_HS, --Active-Low Horizontal Sync
		VGA_VS : out std_logic; --Active-Low Vertical Sync
		VGA_R, VGA_G, VGA_B : out std_logic_vector(3 downto 0)
end vga;
architecture rtl of vga is
--Video parameters
	constant HTOTAL : integer := 800;
	constant HSYNC : integer := 96;
	constant HBACK_PORCH : integer := 48;
	constant HACTIVE : integer := 640;
	constant HFRONT_PORCH : integer := 16;
	constant VTOTAL : integer := 525;
	constant VSYNC : integer := 2;
	constant VBACK_PORCH : integer := 33;
	constant VACTIVE : integer := 480;
	constant VFRONT_PORCH : integer := 10;
	constant RECTANGLE_HSTART : integer := 100;
	constant RECTANGLE_HEND : integer := 540;
	constant RECTANGLE_VSTART : integer := 100;
	constant RECTANGLE_VEND : integer := 380;
--Horizontal position (0-800)
	signal Hcount : std_logic_vector(3 downto 0);
--Vertical position (0-524)
	signal Vcount : std_logic_vector(3 downto 0);
	signal EndOfLine, EndOfField : std_logic;
	signal vga_hblank, vga_hsync,vga_vblank, vga_vsync : std_logic; --Sync. signals
	signal rectangle_h, rectangle_v, rectangle : std_logic; --rectangle area
	signal clk : std_logic; --Should be 25.125 MHz
begin
	CDivider : process (clk_default)
  begin
    if clk_default'event and clk_default = '1' then
      if (clk = '0') then
        clk <= '1';
      else
        clk <= '0';
      end if;
    end if;
  end process CDivider;
	HCounter : process (clk, reset)
	begin
		if reset = '1' then
			Hcount <= (others => '0');
		elsif clk'event and clk = '1' then
			if EndOfLine = '1' then
			else
				Hcount <= Hcount + 1;
			end if;
		end if;
	end process HCounter;
	EndOfLine <= '1' when Hcount = HTOTAL - 1 else '0';
	VCounter: process (clk, reset)
	begin
		if reset = '1' then
			Vcount <= (others => '0');
				if EndOfField = '1' then
				else
					Vcount <= Vcount + 1;
				end if;
			end if;
		end if;
	end process VCounter;
	EndOfField <= '1' when Vcount = VTOTAL - 1 else '0';
	HSyncGen : process (clk, reset)
	begin
		if reset = '1' then
			vga_hsync <= '1';
				vga_hsync <= '1';
			elsif Hcount = HSYNC - 1 then
				vga_hsync <= '0';
			end if;
		end if;
	end process HSyncGen;
	HBlankGen : process (clk, reset)
	begin
		if reset = '1' then
			vga_hblank <= '1';
			if Hcount = HSYNC + HBACK_PORCH then
				vga_hblank <= '0';
			elsif Hcount = HSYNC + HBACK_PORCH + HACTIVE then
				vga_hblank <= '1';
			end if;
		end if;
	end process HBlankGen;
	VSyncGen : process (clk, reset)
	begin
		if reset = '1' then
			vga_vsync <= '1';
			if EndOfLine ='1' then
					vga_vsync <= '1';
				elsif Vcount = VSYNC - 1 then
					vga_vsync <= '0';
				end if;
			end if;
		end if;
	end process VSyncGen;
	VBlankGen : process (clk, reset)
	begin
		if reset = '1' then
			vga_vblank <= '1';
				if Vcount = VSYNC + VBACK_PORCH - 1 then
					vga_vblank <= '0';
				elsif Vcount = VSYNC + VBACK_PORCH + VACTIVE - 1 then
					vga_vblank <= '1';
				end if;
			end if;
		end if;
	end process VBlankGen;
	RectangleHGen : process (clk, reset)
	begin
		if reset = '1' then
			rectangle_h <= '1';
			if Hcount = HSYNC + HBACK_PORCH + RECTANGLE_HSTART then
				rectangle_h <= '1';
			elsif Hcount = HSYNC + HBACK_PORCH + RECTANGLE_HEND then
				rectangle_h <= '0';
			end if;
		end if;
	end process RectangleHGen;
	RectangleVGen : process (clk, reset)
	begin
		if reset = '1' then
			rectangle_v <= '0';
				if Vcount = VSYNC + VBACK_PORCH - 1 + RECTANGLE_VSTART then
					rectangle_v <= '1';
				elsif Vcount = VSYNC + VBACK_PORCH - 1 + RECTANGLE_VEND then
					rectangle_v <= '0';
				end if;
			end if;
		end if;
	end process RectangleVGen;
	rectangle <= rectangle_h and rectangle_v;
	VideoOut: process (clk, reset)
	begin
	if reset = '1' then
		VGA_R <= "0000";
		VGA_G <= "0000";
		VGA_B <= "0000";
		if rectangle = '1' then
			VGA_R <= "1111";
			VGA_G <= "1111";
			VGA_B <= "1111";
		elsif vga_hblank = '0' and vga_vblank ='0' then
			VGA_R <= "0000";
			VGA_G <= "0000";
			VGA_B <= "1111";
		else
			VGA_R <= "0000";
			VGA_G <= "0000";
			VGA_B <= "0000";
		end if;
	end if;
	end process VideoOut;
--	VGA_CLK <= clk;
	VGA_HS <= not vga_hsync;
	VGA_VS <= not vga_vsync;
--	VGA_SYNC <= '0';
--	VGA_BLANK <= not (vga_hsync or vga_vsync);
end rtl;
    As Tricky mentions, making your own clock (divider) is not good design practice. That aside, this is not the major problem in your design.
    You have used signals that are not connected to pins of your DE0 board.
    I added external pins BUTTON and CLOCK_50 instead of your reset and clk_default.
    Also the vectors Hcount and Vcount were too small: 4 bit vectors to represent horizontal position from 0-800 as well as vertical position 0-524.
    With the adapted code below it runs on my DE0.
    library ieee;
    entity vga is
     port (
    --  reset : in std_logic;
    --  clk_default : in std_logic; --default is 50 MHz
          BUTTON : in std_logic_vector (2 downto 0);    -- Sanmao
      CLOCK_50 : in std_logic;                      -- Sanmao
    end vga;
    --Video parameters
     signal Hcount : std_logic_vector(9 downto 0);  -- Sanmao
     signal Vcount : std_logic_vector(9 downto 0);  -- Sanmao
     signal clk_default : std_logic;
     signal reset : std_logic;
    begin
      begin
          if (clk = '0') then
            clk <= '1';
          else
            clk <= '0';
          end if;
        end if;
     begin
      if reset = '1' then
       else
       end if;
      end if;
     begin
      if reset = '1' then
        else
        end if;
       end if;
      end if;
     begin
      if reset = '1' then
       vga_hsync <= '1';
        vga_hsync <= '1';
        vga_hsync <= '0';
       end if;
      end if;
     begin
      if reset = '1' then
       vga_hblank <= '1';
        vga_hblank <= '0';
        vga_hblank <= '1';
       end if;
      end if;
     begin
      if reset = '1' then
       vga_vsync <= '1';
         vga_vsync <= '1';
         vga_vsync <= '0';
        end if;
       end if;
      end if;
     begin
      if reset = '1' then
       vga_vblank <= '1';
         vga_vblank <= '0';
         vga_vblank <= '1';
        end if;
       end if;
      end if;
     begin
      if reset = '1' then
       rectangle_h <= '1';
        rectangle_h <= '1';
        rectangle_h <= '0';
       end if;
      end if;
     begin
      if reset = '1' then
       rectangle_v <= '0';
         rectangle_v <= '1';
         rectangle_v <= '0';
        end if;
       end if;
      end if;
     begin
     if reset = '1' then
      VGA_R <= "0000";
      VGA_G <= "0000";
      VGA_B <= "0000";
       VGA_R <= "1111";
       VGA_G <= "1111";
       VGA_B <= "1111";
       VGA_R <= "0000";
       VGA_G <= "0000";
       VGA_B <= "1111";
      else
       VGA_R <= "0000";
       VGA_G <= "0000";
       VGA_B <= "0000";
      end if;
     end if;
    -- VGA_CLK <= clk;
     clk_default <= CLOCK_50;  -- Sanmao
     reset <= not BUTTON(0);   -- Sanmao
    -- VGA_SYNC <= '0';
    end rtl;
    Good luck with Tetris!
    I think the main problem is that you are dividing your clock by two to generate a logic clock. This is generally a bad thing to do. You should clock everything from the main clock and then produce clock enables when everything needs to change.
    Did you connect your signals correctly?
    For example:
    "clk_default" to CLOCK_50
    "reset" to the inverse of the BUTTON signals
    Hope this works...
