15 years agoproblems on my thesis
Heyy I'm doing my thesis on tetris game simulation on fpga and not good at vhdl that much. Your asist would be great. At first, i need to make the code below work. It's just the beginning of VGA code...
15 years agoAs Tricky mentions, making your own clock (divider) is not good design practice. That aside, this is not the major problem in your design.
You have used signals that are not connected to pins of your DE0 board. I added external pins BUTTON and CLOCK_50 instead of your reset and clk_default. Also the vectors Hcount and Vcount were too small: 4 bit vectors to represent horizontal position from 0-800 as well as vertical position 0-524. With the adapted code below it runs on my DE0.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity vga is
port (
-- reset : in std_logic;
-- clk_default : in std_logic; --default is 50 MHz
BUTTON : in std_logic_vector (2 downto 0); -- Sanmao
CLOCK_50 : in std_logic; -- Sanmao
-- VGA_CLK, --Dot clock to DAC
-- VGA_BLANK, --Active-Low DAC blanking control
-- VGA_SYNC, --Active-Low DAC Sync on Green
VGA_HS, --Active-Low Horizontal Sync
VGA_VS : out std_logic; --Active-Low Vertical Sync
VGA_R, VGA_G, VGA_B : out std_logic_vector(3 downto 0)
end vga;
architecture rtl of vga is
--Video parameters
constant HTOTAL : integer := 800;
constant HSYNC : integer := 96;
constant HBACK_PORCH : integer := 48;
constant HACTIVE : integer := 640;
constant HFRONT_PORCH : integer := 16;
constant VTOTAL : integer := 525;
constant VSYNC : integer := 2;
constant VBACK_PORCH : integer := 33;
constant VACTIVE : integer := 480;
constant VFRONT_PORCH : integer := 10;
constant RECTANGLE_HSTART : integer := 100;
constant RECTANGLE_HEND : integer := 540;
constant RECTANGLE_VSTART : integer := 100;
constant RECTANGLE_VEND : integer := 380;
--Horizontal position (0-800)
signal Hcount : std_logic_vector(9 downto 0); -- Sanmao
--Vertical position (0-524)
signal Vcount : std_logic_vector(9 downto 0); -- Sanmao
signal EndOfLine, EndOfField : std_logic;
signal vga_hblank, vga_hsync,vga_vblank, vga_vsync : std_logic; --Sync. signals
signal rectangle_h, rectangle_v, rectangle : std_logic; --rectangle area
signal clk : std_logic; --Should be 25.125 MHz
signal clk_default : std_logic;
signal reset : std_logic;
begin
CDivider : process (clk_default)
begin
if clk_default'event and clk_default = '1' then
if (clk = '0') then
clk <= '1';
else
clk <= '0';
end if;
end if;
end process CDivider;
HCounter : process (clk, reset)
begin
if reset = '1' then
Hcount <= (others => '0');
elsif clk'event and clk = '1' then
if EndOfLine = '1' then
else
Hcount <= Hcount + 1;
end if;
end if;
end process HCounter;
EndOfLine <= '1' when Hcount = HTOTAL - 1 else '0';
VCounter: process (clk, reset)
begin
if reset = '1' then
Vcount <= (others => '0');
if EndOfField = '1' then
else
Vcount <= Vcount + 1;
end if;
end if;
end if;
end process VCounter;
EndOfField <= '1' when Vcount = VTOTAL - 1 else '0';
HSyncGen : process (clk, reset)
begin
if reset = '1' then
vga_hsync <= '1';
vga_hsync <= '1';
elsif Hcount = HSYNC - 1 then
vga_hsync <= '0';
end if;
end if;
end process HSyncGen;
HBlankGen : process (clk, reset)
begin
if reset = '1' then
vga_hblank <= '1';
if Hcount = HSYNC + HBACK_PORCH then
vga_hblank <= '0';
elsif Hcount = HSYNC + HBACK_PORCH + HACTIVE then
vga_hblank <= '1';
end if;
end if;
end process HBlankGen;
VSyncGen : process (clk, reset)
begin
if reset = '1' then
vga_vsync <= '1';
if EndOfLine ='1' then
vga_vsync <= '1';
elsif Vcount = VSYNC - 1 then
vga_vsync <= '0';
end if;
end if;
end if;
end process VSyncGen;
VBlankGen : process (clk, reset)
begin
if reset = '1' then
vga_vblank <= '1';
if Vcount = VSYNC + VBACK_PORCH - 1 then
vga_vblank <= '0';
elsif Vcount = VSYNC + VBACK_PORCH + VACTIVE - 1 then
vga_vblank <= '1';
end if;
end if;
end if;
end process VBlankGen;
RectangleHGen : process (clk, reset)
begin
if reset = '1' then
rectangle_h <= '1';
if Hcount = HSYNC + HBACK_PORCH + RECTANGLE_HSTART then
rectangle_h <= '1';
elsif Hcount = HSYNC + HBACK_PORCH + RECTANGLE_HEND then
rectangle_h <= '0';
end if;
end if;
end process RectangleHGen;
RectangleVGen : process (clk, reset)
begin
if reset = '1' then
rectangle_v <= '0';
if Vcount = VSYNC + VBACK_PORCH - 1 + RECTANGLE_VSTART then
rectangle_v <= '1';
elsif Vcount = VSYNC + VBACK_PORCH - 1 + RECTANGLE_VEND then
rectangle_v <= '0';
end if;
end if;
end if;
end process RectangleVGen;
rectangle <= rectangle_h and rectangle_v;
VideoOut: process (clk, reset)
begin
if reset = '1' then
VGA_R <= "0000";
VGA_G <= "0000";
VGA_B <= "0000";
if rectangle = '1' then
VGA_R <= "1111";
VGA_G <= "1111";
VGA_B <= "1111";
elsif vga_hblank = '0' and vga_vblank ='0' then
VGA_R <= "0000";
VGA_G <= "0000";
VGA_B <= "1111";
else
VGA_R <= "0000";
VGA_G <= "0000";
VGA_B <= "0000";
end if;
end if;
end process VideoOut;
-- VGA_CLK <= clk;
VGA_HS <= not vga_hsync;
VGA_VS <= not vga_vsync;
clk_default <= CLOCK_50; -- Sanmao
reset <= not BUTTON(0); -- Sanmao
-- VGA_SYNC <= '0';
-- VGA_BLANK <= not (vga_hsync or vga_vsync);
end rtl;
Good luck with Tetris!
