16 years agoproblem with niosII ISS configuration
hi,
i try to work with quartusII(V9),nios(V9).So i want to run a program with niosII ide (run as NiosII Instruction Set Simulator)(i use the standard stratixII_2s60_RoHs). These warnings appear,and i haven't any result: warning : sopc builder system component pll is not supported by the simulator. simulation may be incorrect if your software attempts to access it
warning : sopc builder system component sysid is not supported by the simulator.
warning : sopc builder system component reconfig_request_pio is not supported by
it
warning : sopc builder system component lan91c111 is not supported by the simula
warning : sopc builder system component lcd_display is not supported by the simu
warning : sopc builder system component button_pio is not supported by the simul
warning : sopc builder system component led_pio is not supported by the simulato
warning : sopc builder system component seven_seg_pio is not supported by the si
And this error: error! : simulation failed in component cpu at instruction 1381386 (pc=0x4007220 instr=0x183ee83a). If any one has an idea about this problem please help me:confused::confused::confused:
1 Reply
The ISS is not actively developed (or supported). The messages indicate that you can NOT have any code which accesses the components that are mentioned... Lauterbach offers a more feature complete iss for nios ii (http://www.altera.com/products/ip/processors/nios2/tools/embed-partners/lauterbach/emb-lauterbach.html).
Cheers, -slacker
