problem to program an arria10GX with active serial
Dear all,
I am working on a card based on ARRIA10GX.
I want to program the FPGA with the active serial configuration.
I programmed the flash memory (MT25QU01G) a first time but unfortunately the file was not good because now the FPGA performs an automatic reboot after error and I cannot access the FPGA through the JTAG.
my questions are:
- can we stop this cycling
- the FLASH memory (through the dedicated Active serial pins) can it access in another configuration mode
thank you
- NurAiman_M_Intel
Arria 10 GX flash memory can only use Active Serial configuration mode. Per my understanding, your issue here is:
Arria 10 GX MT25QU01G flash memory only support 4-bytes address. The flash memory come with 3-bytes address and you might need to set the address to 4-bytes manually if you are using your own programming. By referring to https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/configuration-support.html, it mention that "User need to set the register manually if using a third party programmer."
Please inform me if you need further information.
Aiman
- JBouv2
thank you for your reply
I use my own script to program the flash memory, I use the "generic serial flash interface" hardware IP and a .rpd file
I follow the design as shown in Arria 10 GX user guide.
but my problem now is to access the serial flash to delete it. is there a way to access the memory in a mode other than active serial?
regards
- NurAiman_M_Intel
Please clarify the following:
-how did you program the flash memory: using quartus or your own script?
-what is the format of the bit stream that you have generated? Are u using rbf, rpd,jic or sof file?
-since using AS config mode, have you followed the design as shown in Arria 10 GX user guide?
Aim
