JBouv2
6 years agoproblem to program an arria10GX with active serial
Dear all, I am working on a card based on ARRIA10GX. I want to program the FPGA with the active serial configuration. I programmed the flash memory (MT25QU01G) a first time but unfortunately the f...
NurAiman_M_Intel
6 years agoHi,
Arria 10 GX flash memory can only use Active Serial configuration mode. Per my understanding, your issue here is:
Arria 10 GX MT25QU01G flash memory only support 4-bytes address. The flash memory come with 3-bytes address and you might need to set the address to 4-bytes manually if you are using your own programming. By referring to https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/configuration-support.html, it mention that "User need to set the register manually if using a third party programmer."
Please inform me if you need further information.
Aiman
