JBouv2
6 years agoproblem to program an arria10GX with active serial
Dear all, I am working on a card based on ARRIA10GX. I want to program the FPGA with the active serial configuration. I programmed the flash memory (MT25QU01G) a first time but unfortunately the f...
NurAiman_M_Intel
6 years agoHi,
Please clarify the following:
-how did you program the flash memory: using quartus or your own script?
-what is the format of the bit stream that you have generated? Are u using rbf, rpd,jic or sof file?
-since using AS config mode, have you followed the design as shown in Arria 10 GX user guide?
Aim
