15 years ago
Problem simulating FIFO at Modelsim
Hello i used the FIFO from megawizard and i can't simulate it at modelsim, i am trying to add the altera_mf library but all my tries are worthless..
please help! This is my error
vsim work.tb_fifo#  vsim work.tb_fifo #  Loading work.tb_fifo#  Loading work.fifowrapper#  ** Warning: (vsim-3009)  - Module 'fifowrapper' does not have a `timescale directive in effect, but previous modules do.#          Region: /tb_fifo/u0#  Loading work.base#  ** Error: (vsim-3033) C:/DHW/Projetos/dmafifo/base.v(82): Instantiation of 'dcfifo' failed. The design unit was not found.#          Region: /tb_fifo/u0/fifo_inst#          Searched libraries:#              C:\DHW\Projetos\dmafifo\tb\work#  Error loading design
    What kind of HDL you mean?
    module fifowrapper(
                        // inputs:
                         rdclk,
                                rstn,
                                rdreq,
                        // outputs:
                         valid,
                         q
    input  rdclk;
    input rdreq;
    input rstn;
    reg rdreqtemp;
    reg wrclk;
    reg wrreq;
    output  q;
    output reg valid;
    wire  data;
    reg  data_in;
    assign data = data_in;
    wire  usedw;
    reg  contador;
    reg  delay;
    always@(posedge rdclk or negedge rstn)
      if (~rstn)
       begin
       valid <= 0;
       contador <= 0;
       data_in <= 0;
       wrreq <= 0;
        delay <= 0;
       end
      else
    begin
            contador <= contador +1;
            valid <= 0;
            wrreq <= 0;
               if(usedw == 6'b100000)
                begin
                    valid <= 1;
                end
                if(contador == 100000000)
                begin
                    wrreq <=1;
                    data_in <= data_in + 32'b00000000000000000000000000000001;
                    contador <= 0;
                end
    end
    base    fifo_inst (
        .data ( data ),
        .rdclk ( rdclk ),
        .rdreq ( rdreq ),
        .wrclk ( rdclk ),
        .wrreq ( wrreq ),
        .q ( q ),
    //    .rdempty ( rdempty_sig ),
    //    .rdusedw ( usedw )
        .wrusedw ( usedw )
    //    .wrfull ( wrfull_sig )
    endmodule
    This is my wrapper
    and this if my testbench
     `timescale 1 ns/1 ns
    module tb_fifo;
    parameter P_CLKPERIOD = 50;
    reg tb_i_clk;
    reg tb_i_rstn;
    wire tb_valor;
    //CLOCK DO SISTEMA EM 50ns - 20Mhz
    initial tb_i_clk = 1'b1;
    always# (P_CLKPERIOD/2) tb_i_clk <= ~tb_i_clk;
    // RESET DO SISTEMA
    initial
    begin
        @(posedge tb_i_clk);
        tb_i_rstn <= 0;
       # 10;
        tb_i_rstn <= 1;
    end
    // BLOCO PRINCIPAL
    fifowrapper u0(
        .rdclk (tb_i_clk),
        .rstn (tb_i_rstn),
        // outputs:
        .valid(tb_valor)
        //.q
    endmodule
    if you post some HDL i'll try and take a look. you can just isolate it to the test bench and FIFO
    i see all the libraries there but i can't make modelsim search theree
    ModelSim-ASE should have the altera_mf libraries precompiled and installed. however, from your simulation:
    it doesn't look like it is searching through all of the Altera libraries. in ModelSim's Libraries window, do you see just the work library or a list of various libraries?
    yes i am using modelsim ASE.. it is possible?
    I didnt compile them into work, can you tell me how? Going to read the docs you told me to. Thanks
