15 years agoProblem simulating FIFO at Modelsim
Hello i used the FIFO from megawizard and i can't simulate it at modelsim, i am trying to add the altera_mf library but all my tries are worthless.. please help! This is my error vsim work....
15 years agodid you compile altera_mf into altera_mf or into work?
these docs should help: http://www.altera.com/literature/hb/qts/qts_qii53001.pdf http://www.altera.com/literature/hb/qts/qts_qii53025.pdf you must not be using ModelSim-A(S)E?
