15 years agoProblem simulating FIFO at Modelsim
Hello i used the FIFO from megawizard and i can't simulate it at modelsim, i am trying to add the altera_mf library but all my tries are worthless.. please help! This is my error vsim work....
15 years agoWhat kind of HDL you mean?
module fifowrapper(
// inputs:
rdclk,
rstn,
rdreq,
// outputs:
valid,
q
input rdclk;
input rdreq;
input rstn;
reg rdreqtemp;
reg wrclk;
reg wrreq;
output q;
output reg valid;
wire data;
reg data_in;
assign data = data_in;
wire usedw;
reg contador;
reg delay;
always@(posedge rdclk or negedge rstn)
if (~rstn)
begin
valid <= 0;
contador <= 0;
data_in <= 0;
wrreq <= 0;
delay <= 0;
end
else
begin
contador <= contador +1;
valid <= 0;
wrreq <= 0;
if(usedw == 6'b100000)
begin
valid <= 1;
end
if(contador == 100000000)
begin
wrreq <=1;
data_in <= data_in + 32'b00000000000000000000000000000001;
contador <= 0;
end
end
base fifo_inst (
.data ( data ),
.rdclk ( rdclk ),
.rdreq ( rdreq ),
.wrclk ( rdclk ),
.wrreq ( wrreq ),
.q ( q ),
// .rdempty ( rdempty_sig ),
// .rdusedw ( usedw )
.wrusedw ( usedw )
// .wrfull ( wrfull_sig )
endmodule
This is my wrapper and this if my testbench
`timescale 1 ns/1 ns
module tb_fifo;
parameter P_CLKPERIOD = 50;
reg tb_i_clk;
reg tb_i_rstn;
wire tb_valor;
//CLOCK DO SISTEMA EM 50ns - 20Mhz
initial tb_i_clk = 1'b1;
always# (P_CLKPERIOD/2) tb_i_clk <= ~tb_i_clk;
// RESET DO SISTEMA
initial
begin
@(posedge tb_i_clk);
tb_i_rstn <= 0;
# 10;
tb_i_rstn <= 1;
end
// BLOCO PRINCIPAL
fifowrapper u0(
.rdclk (tb_i_clk),
.rstn (tb_i_rstn),
// outputs:
.valid(tb_valor)
//.q
endmodule
