16 years agoProblem in FIR Compiler v9.1
I use FIR Complier v9.1 to generate a FIR filter. However, it does not generate the netlist file (<variation name>_st.v).
When I do synthsis, it shows the error "Error: Node instance "fircore" instantiates undefined entity "filter_st" File". There is no problem to use MegaWizard to generate other IP, such as multiplier or CIC. Any help are very appreciated.2 Replies
Copied this from the other thread...
Found the solution: download and install/repair Microsoft Visual C++ 2008 SP1 Redistributable Package. Also, make sure the latest version of Java is installed. http://www.microsoft.com/downloads/details.aspx?familyid=a5c84275-3b97-4ab7-a40d-3802b2af5fc2&displaylang=en - Altera_Forum
I have the same issue and cannot find a workaround/resolution.
