16 years agoProblem in FIR Compiler v9.1
I use FIR Complier v9.1 to generate a FIR filter. However, it does not generate the netlist file (<variation name>_st.v). When I do synthsis, it shows the error "Error: Node instance "fircore...
16 years agoCopied this from the other thread...
Found the solution: download and install/repair Microsoft Visual C++ 2008 SP1 Redistributable Package. Also, make sure the latest version of Java is installed. http://www.microsoft.com/downloads/details.aspx?familyid=a5c84275-3b97-4ab7-a40d-3802b2af5fc2&displaylang=en
