14 years agoPin Assignment problem
I could not find locations associated with these pins on ep4cgx15bf14c8. Can anyone help me? :) Critical Warning (169085): No exact pin location assignment(s) for 4 pins of 52 total pins
Inf...
14 years agoI don't remember how the tristate master works, but I think you can configure it so that it shares the output enable between the flash and the ssram, so that you have only one signal to connect.
As for the other ones, I don't know which mode the ssram controller uses, but you could at first try not to connect them. Just ensure that the two individual byte write enable signals are well connected, and then you can forget about the global write. Don't you have a design example you can have a look to, so that you can see how it was implemented?
