Avi_V_888's avatar
Avi_V_888
4 years ago
PCIe Gen 4 16 Lanes Core in Agilex - ready out signal behave
I am using PCIe gen 4 (16 lanes) (512bit/500MHz clk , payload size:512B) CORE, in Agilex device: AGFB014R24A2E2VR0, for transfer DMA writings from the FPGA to the PC’s memory.
Since the rate of the ready out signal (coming from the PCIe core) toggling is not constant, a FIFO must be placed between the data source (Sensor) and the DMA, to absorb the volatility.
The problem is the ready signal stays in off position for a long time (instead of toggling more homogeneously) and causes the FIFO to overflow (I'm talking about FIFO in the size of 64MB).
Are you familiar with this issue ?
What do you think can be done to make the ready signal not to create such long breaks, but to disperse them over time for a number of short breaks?
Avi
  • Wincent_Altera's avatar
    Wincent_Altera
    I saw in the system, your question has been addressed in IPS.
    I will set this as close, if you have any other questions in the future feel free to open a new case.
    WeiChuan_C_Intel
    Wincent_Altera
    Hi Avi,
    As a start, Programs that become unresponsive can be due to a myriad of reasons and might be difficult to pinpoint exactly.
    However, I've laid out some suggestions to help you narrow this down further. As a normal data transfer condition, FIFO buffer overflow normally does not occurs, but it can result if there is a programming error. Example transmit PBL =4, TX watermark =1, if the FIFO buffer has only one location empty, the DMA attempts to read four words from memory even though there is only one word of storage available. This results in a FIFO Buffer Overflow interrupt.
    The driver must ensure that the number of bytes to be transferred, as indicated in the descriptor, is a multiple of four bytes. For example, if the bytcnt register = 13, the number of bytes indicated in the descriptor must be rounded up to 16 because the length field must always be a multiple of four bytes.
    Please let me know if it is helpful.
    WeiChuan_C_Intel
      Wincent_Altera
      We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
      WeiChuan_C_Intel
      • Avi_V_888's avatar
        Avi_V_888
        First of all sorry for the delay in my response , I switched to another urgent short mission.
        I checked the FIFO management and found that everything is fine in terms of the reason you mentioned.
        Can you tell me the size of the FIFO that other developers have had to place in order to absorb the volatility of the ready signal coming from the PCIe4 core?
        If there is not yet enough data for gen 4 , I would happy to get an answer even for gen 3.
        Avi
