14 years ago
Parallel output ADC, LVDS
Im trying to interface a TI ADS3848 ADC with my stratix-III board. The ADC uses a 14 word, parallel LVDS output ie, 28 pins.
I've read many posts on the forums having to do with getting LVDS stuff to work by using the iobuff megafunction or the lvds_TX/RX megafunctions. My question is as follows:
The ADC has 14 "2 wire" output lines. Each output consists of a positive "p" and a negative "n". The documentation for the iobuff and LVDS_TX/RX suggest the notion that quartus automatically "finds" the other polarity wire after assigning only one side. How is this possible?
Matt
    Cool. It worked. Seems obvious that that is what the pin planner is supposed to do. Don't know why i thought otherwise.
    --- Quote Start ---
    --- Quote End ---
    Its not that it automatically finds them, its that the p/n pairs are hard-wired. So if your board has been routed for LVDS, then the board designer will have routed the p/n pairs as differential signals. In Quartus, once you define the p signal as being LVDS, this 'implies' the n signal of the LVDS pair, so you do not need to apply a constraint.
    Check your board schematic, and then check the pin assignments view.
    Cheers,
    Dave
    If the device has high-speed serializers, I would suggest using them. Just instantiate the altlvds_rx block, which will only take in a 14 bit bus, but you will assign the I/O standard to be LVDS, so a n-pair for each one gets created.
