I am going to correct my final data on my pc as a lot easier then trying to correct for it on the FPGA.
Thanks alot for your help in this. - Altera_Forum
I think that outputs of DAC have amplitude diffirent with frequences diffirent. Because ouput of DAC forma sin(x)/x.
I have the same problem with stratix2 dsp evaluation board. I built a simple fsk modulator on NCO. The output is 10 kHz for '0' and 15khz for '1'. I use all 14 bits of DAC. The amplitudes differs about 50-100 mVolts. In the simulations everything looks ok. I also try to understand what the problem is. - Altera_Forum
In this case you can easily overcome the difference by prescaling both to become equal after DAC(simplest case of equaliser)
--- Quote Start --- Hi, I have the same problem with stratix2 dsp evaluation board. I built a simple fsk modulator on NCO. The output is 10 kHz for '0' and 15khz for '1'. I use all 14 bits of DAC. The amplitudes differs about 50-100 mVolts. In the simulations everything looks ok. I also try to understand what the problem is. --- Quote End --- Do You Have the project to share?
