17 years agoOutput amplitute from an NCO
Am i right in thinking that the output amplitutde from the NCO is not constant over different frequencies?
14 years ago --- Quote Start --- Hi, I have the same problem with stratix2 dsp evaluation board. I built a simple fsk modulator on NCO. The output is 10 kHz for '0' and 15khz for '1'. I use all 14 bits of DAC. The amplitudes differs about 50-100 mVolts. In the simulations everything looks ok. I also try to understand what the problem is. --- Quote End --- Do You Have the project to share?
