14 years agoone shot and D flip flops
Greetings.
What is the advantage of putting one shots (one clock pulse if the D in a flip flop goes high) and basic D flip flops in designs? I see them placed in a lot of designs I look and and wonder if there are certain rules experienced designers use for them. When would be a good time to use a "Oneshot" or a "D flip flop" Thanks3 Replies
basically everything involving a clock. They create the pipeline
D types are the basis of all designs. You can use clock enables to move data along the pipeline or not. - Altera_Forum
What is then the best use for D flip flops in a design?
thanks for the reply - Altera_Forum
using the outputs of logic/registers as clocks is a general no-no in FPGAs. You CAN do it, but unless you get the "clock" into a clock net you're going to have timing problems.
Its best to use clock enables (and much less complicated and much easier for another engineer to understand.)
