arulmaniv
9 months agoNOR Flash IC programming using 3rd party Programmer
We have observed that programming the NOR Flash using the Altera USB‑Blaster via JTAG behaves differently compared to programming the same Flash device using a third‑party gang programmer. We hav...
- 8 months ago
we are checking the Quad Bit enable in the NOR Flash IC, Looks like that bit only creating an issues.
FvM
9 months agoHi,
why no reading back jic programmed flash in your programmer and compare the content? May be trivial bit order problem.
Writing binary image files to altasmi IP needs a bitrevers conversion, I guess it's also required for your programmer.
Regards Frank
