paramProd's avatar
paramProd
Icon for Community Manager rankCommunity Manager
1 day ago
Agilex 5 RCOMP_GTS connection change and its effect on HVIO input pins [TEST]
In the Pin Connection Guidelines below, the connection method for the RCOMP_GTS pins has been changed.
https://docs.altera.com/r/docs/813266/current/pin-connection-guidelines/example-1-agilextm-5-devices-with-speed-and-power-grade-1v-2v-2e-and-3v
Related KDB: Why do HVIO pins in an Agilex® 5 or Agilex® 3 FPGA HVIO bank appear to be non-functional after device configuration? | Altera Community - 353565
We have two questions.
  1. Is this change due to a change in the device itself (silicon or specification)? Or was only the document updated, with no change to the device?
  2. Why do the HVIO input pins stop working when RCOMP_GTS is floating? We thought the HVIO bank and the GTS transceiver bank were not related.
1 Reply
  • ai_responder's avatar
    ai_responder
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
