16 years agoNios2 data cache with 32-byte burst error
I took our hardware guy's FPGA (cyclone 2) with Nios2 processor & simply added a data cache with burst (32 bytes), size 512.
It generated OK with SOPC builder (version 9.1 quartus II tools) but in quartus, it errors with... Info: Elaborating entity "g110_core_burst_18_upstream_arbitrator" for hierarchy "g110_core:inst|g110_core_burst_18_upstream_arbitrator:the_g110_core_burst_18_upstream" Warning (10542): VHDL Variable Declaration warning at altera_europa_support_lib.vhd(340): used initial value expression for variable "arg_copy" because variable was never assigned a value Warning (10542): VHDL Variable Declaration warning at altera_europa_support_lib.vhd(344): used initial value expression for variable "arg_length" because variable was never assigned a value Info: Elaborating entity "burstcount_fifo_for_g110_core_burst_18_upstream_module" for hierarchy "g110_core:inst|g110_core_burst_18_upstream_arbitrator:the_g110_core_burst_18_upstream|burstcount_fifo_for_g110_core_burst_18_upstream_module:burstcount_fifo_for_g110_core_burst_18_upstream" Warning (10542): VHDL Variable Declaration warning at altera_europa_support_lib.vhd(340): used initial value expression for variable "arg_copy" because variable was never assigned a value Warning (10542): VHDL Variable Declaration warning at altera_europa_support_lib.vhd(344): used initial value expression for variable "arg_length" because variable was never assigned a value Info: Elaborating entity "rdv_fifo_for_cpu_data_master_to_g110_core_burst_18_upstream_module" for hierarchy "g110_core:inst|g110_core_burst_18_upstream_arbitrator:the_g110_core_burst_18_upstream|rdv_fifo_for_cpu_data_master_to_g110_core_burst_18_upstream_module:rdv_fifo_for_cpu_data_master_to_g110_core_burst_18_upstream" Warning (10542): VHDL Variable Declaration warning at altera_europa_support_lib.vhd(340): used initial value expression for variable "arg_copy" because variable was never assigned a value Warning (10542): VHDL Variable Declaration warning at altera_europa_support_lib.vhd(344): used initial value expression for variable "arg_length" because variable was never assigned a value Info: Elaborating entity "g110_core_burst_18_downstream_arbitrator" for hierarchy "g110_core:inst|g110_core_burst_18_downstream_arbitrator:the_g110_core_burst_18_downstream" Warning: Using design file g110_core_burst_18.vhd, which is not specified as a design file for the current project, but contains definitions for 2 design units and 1 entities in project Info: Found design unit 1: g110_core_burst_18-europa Info: Found entity 1: g110_core_burst_18 Info: Elaborating entity "g110_core_burst_18" for hierarchy "g110_core:inst|g110_core_burst_18:the_g110_core_burst_18" Warning (10542): VHDL Variable Declaration warning at altera_europa_support_lib.vhd(340): used initial value expression for variable "arg_copy" because variable was never assigned a value Warning (10542): VHDL Variable Declaration warning at altera_europa_support_lib.vhd(344): used initial value expression for variable "arg_length" because variable was never assigned a value Info: Elaborating entity "g110_core_burst_19_upstream_arbitrator" for hierarchy "g110_core:inst|g110_core_burst_19_upstream_arbitrator:the_g110_core_burst_19_upstream" Warning (10542): VHDL Variable Declaration warning at altera_europa_support_lib.vhd(340): used initial value expression for variable "arg_copy" because variable was never assigned a value Warning (10542): VHDL Variable Declaration warning at altera_europa_support_lib.vhd(344): used initial value expression for variable "arg_length" because variable was never assigned a value Info: Elaborating entity "burstcount_fifo_for_g110_core_burst_19_upstream_module" for hierarchy "g110_core:inst|g110_core_burst_19_upstream_arbitrator:the_g110_core_burst_19_upstream|burstcount_fifo_for_g110_core_burst_19_upstream_module:burstcount_fifo_for_g110_core_burst_19_upstream" Warning (10542): VHDL Variable Declaration warning at altera_europa_support_lib.vhd(340): used initial value expression for variable "arg_copy" because variable was never assigned a value Warning (10542): VHDL Variable Declaration warning at altera_europa_support_lib.vhd(344): used initial value expression for variable "arg_length" because variable was never assigned a value Info: Elaborating entity "rdv_fifo_for_cpu_data_master_to_g110_core_burst_19_upstream_module" for hierarchy "g110_core:inst|g110_core_burst_19_upstream_arbitrator:the_g110_core_burst_19_upstream|rdv_fifo_for_cpu_data_master_to_g110_core_burst_19_upstream_module:rdv_fifo_for_cpu_data_master_to_g110_core_burst_19_upstream" Warning (10542): VHDL Variable Declaration warning at altera_europa_support_lib.vhd(340): used initial value expression for variable "arg_copy" because variable was never assigned a value Warning (10542): VHDL Variable Declaration warning at altera_europa_support_lib.vhd(344): used initial value expression for variable "arg_length" because variable was never assigned a value Info: Elaborating entity "g110_core_burst_19_downstream_arbitrator" for hierarchy "g110_core:inst|g110_core_burst_19_downstream_arbitrator:the_g110_core_burst_19_downstream" Warning: Using design file g110_core_burst_19.vhd, which is not specified as a design file for the current project, but contains definitions for 2 design units and 1 entities in project Info: Found design unit 1: g110_core_burst_19-europa Info: Found entity 1: g110_core_burst_19 Error (10511): VHDL Qualified Expression error at g110_core_burst_19.vhd(350): A_SRL type specified in Qualified Expression must match std_logic type that is implied for expression by context Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 193 warnings Error: Peak virtual memory: 313 megabytes Error: Processing ended: Wed Apr 28 15:33:10 2010 Error: Elapsed time: 00:00:24 Error: Total CPU time (on all processors): 00:00:20 Error: Quartus II Full Compilation was unsuccessful. 3 errors, 193 warnings The hardware guy says it's an internal error so any idea how to get around this? Paul3 Replies
If any of the custom IP includes an avalon slave with burst capabilities, there could be a type mismatch on one of the burst control signals. Having a look at the line 350 of g110_core_burst_19.vhd may help in finding the problem.
--- Quote Start --- Is g110_core a custom IP in your design? --- Quote End --- g110_core is the project which does contain custom IP - Altera_Forum
