17 years agonios ii flash programming error
Hi:
When I program *.elf to flash ,there something wrong with it. The infomation like # !/bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.# cd E:/altera/80/workplace/RA8835/hello_world_1/Debug# Creating .flash file for the project "$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x00200000 --end=0x3fffff --reset=0x20000 0 --input="hello_world_1.elf" --output="cfi_flash.flash" --boot="E:/altera/80/ip /nios2_ip/altera_nios2/boot_loader_cfi.srec"# Programming flash with the project "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x00200000 --sidp=0x000010b0 --id=148608136 --timestamp=1252545047 --instance=0 "cfi_flash.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x000010B0: verified : Checksumming existing contents 00000000 : Reading existing contents 00004000 : Reading existing contents Checksummed/read 7kB in 0.2s 00000000 ( 0%): Erasing 00004000 (66%): Erasing Erased 24kB in 0.4s (60.0kB/s) 00000000 ( 0%): Programming 00004000 (66%): Programming Programmed 18KB +6KB in 0.3s (80.0KB/s) Verify failed at offset 0 Verify failed at offset 4000 Leaving target processor paused //end Who can help me resave it?Please! Thanks20 Replies
I program sof to EPCS4 first ,and then program *.elf to flash by NIOS_IDE_flash_programmer.
Something wrong with me? - Altera_Forum
Can you provide more details?
First ,in a new project,I build a sopc_builder system,and add CPU,tristate_bridge,cfi_flash,sram and some PIOs.
In nios_processor setting ,reset vector set as cfi_flash, offset set as 0x0 ,then run Auto_assign_Base_address and Auto_assign_IRQs in System_view, last I generate the nios_system. After generate OK and assign Pins OK! I compile quartus_project! Then open the nios_ide,build software_project,set system_library_propetities, compile system.When does this OK,I program quartus_project first and then program elf to flash by NIOS_TOOL_FLASH_PROGRAMMER. - Altera_Forum
Have you tried to run your program without using the flash?
Just normally after programming hardware, launch Run as-> Nios II hardware. Does it work? - Altera_Forum
Yes ,it works well!
What hardware do u use? A dev-kit or your own PCB?
My own pcb!
Hi! I have the same problem!!
# !/bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.# cd G:/nios_ii_sw/led_blink_8bit/software/led_blink_8bit/Debug# Creating .flash file for the project "$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x02400000 --end=0x27fffff --reset=0x2400 000 --input="led_blink_8bit.elf" --output="cfi_flash.flash" --boot="D:/altera/90 /ip/altera/nios2_ip/altera_nios2/boot_loader_cfi.srec"# Programming flash with the project "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x02400000 --cable='USB-Blas ter [USB-0]' --sidp=0x02801010 --id=2017564571 --timestamp=1277911500 --instance =0 "cfi_flash.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x02801010: verified : Checksumming existing contents 00004000 : Verifying existing contents 00006000 : Verifying existing contents 00008000 : Verifying existing contents 00000000 : Reading existing contents Checksummed/read 46kB in 4.9s 00000000 ( 0%): Erasing Erased 16kB in 0.5s (32.0kB/s) 00000000 ( 0%): Programming 00004000 (25%): Programming 00006000 (25%): Programming 00008000 (25%): Programming Programmed 62KB in 0.9s (68.8KB/s) Verify failed at offset 4000 Verify failed at offset 6000 Verify failed at offset 8000 Leaving target processor paused //////////////////////////////////////// Have you solved this problem? My flash is set the 8bit databus connect to FPGA(EP2C5),when 16bit databus is no this problem. further more this problem usually appear when I compile the code and first download the .elf; when I download the same .elf to the flash in the secondtime ,it works. This is very strange!! - Altera_Forum
The secondtime download ,it works:
# !/bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.# cd G:/nios_ii_sw/led_blink_8bit/software/led_blink_8bit/Debug# Creating .flash file for the project "$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x02400000 --end=0x27fffff --reset=0x2400 000 --input="led_blink_8bit.elf" --output="cfi_flash.flash" --boot="D:/altera/90 /ip/altera/nios2_ip/altera_nios2/boot_loader_cfi.srec"# Programming flash with the project "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x02400000 --cable='USB-Blas ter [USB-0]' --sidp=0x02801010 --id=2017564571 --timestamp=1277911500 --instance =0 "cfi_flash.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x02801010: verified : Checksumming existing contents 00000000 : Verifying existing contents Checksummed/read 16kB in 2.1s Erase not required 00000000 ( 0%): Programming 00004000 ( 0%): Programming 00006000 (12%): Programming 00008000 (25%): Programming Programmed 62KB in 2.5s (24.8KB/s) Device contents checksummed OK Leaving target processor paused - Altera_Forum
@shiy
I also have the same problem ....Can you please me tell me how you solved the problem....
