17 years agonios ii flash programming error
Hi: When I program *.elf to flash ,there something wrong with it. The infomation like # !/bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be ...
17 years agoFirst ,in a new project,I build a sopc_builder system,and add CPU,tristate_bridge,cfi_flash,sram and some PIOs.
In nios_processor setting ,reset vector set as cfi_flash, offset set as 0x0 ,then run Auto_assign_Base_address and Auto_assign_IRQs in System_view, last I generate the nios_system. After generate OK and assign Pins OK! I compile quartus_project! Then open the nios_ide,build software_project,set system_library_propetities, compile system.When does this OK,I program quartus_project first and then program elf to flash by NIOS_TOOL_FLASH_PROGRAMMER.
