17 years agonios ii flash programming error
Hi: When I program *.elf to flash ,there something wrong with it. The infomation like # !/bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be ...
16 years agoThe secondtime download ,it works:
# !/bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.# cd G:/nios_ii_sw/led_blink_8bit/software/led_blink_8bit/Debug# Creating .flash file for the project "$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x02400000 --end=0x27fffff --reset=0x2400 000 --input="led_blink_8bit.elf" --output="cfi_flash.flash" --boot="D:/altera/90 /ip/altera/nios2_ip/altera_nios2/boot_loader_cfi.srec"# Programming flash with the project "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x02400000 --cable='USB-Blas ter [USB-0]' --sidp=0x02801010 --id=2017564571 --timestamp=1277911500 --instance =0 "cfi_flash.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x02801010: verified : Checksumming existing contents 00000000 : Verifying existing contents Checksummed/read 16kB in 2.1s Erase not required 00000000 ( 0%): Programming 00004000 ( 0%): Programming 00006000 (12%): Programming 00008000 (25%): Programming Programmed 62KB in 2.5s (24.8KB/s) Device contents checksummed OK Leaving target processor paused
