16 years ago
nios ii flash programming error
Hi:
When I program *.elf to flash ,there something wrong with it.
The infomation like
# !/bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.#
cd E:/altera/80/workplace/RA8835/hello_world_1/Debug# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x00200000 --end=0x3fffff --reset=0x20000
0 --input="hello_world_1.elf" --output="cfi_flash.flash" --boot="E:/altera/80/ip
/nios2_ip/altera_nios2/boot_loader_cfi.srec"# Programming flash with the project
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x00200000 --sidp=0x000010b0
--id=148608136 --timestamp=1252545047 --instance=0 "cfi_flash.flash"
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x000010B0: verified
: Checksumming existing contents
00000000 : Reading existing contents
00004000 : Reading existing contents
Checksummed/read 7kB in 0.2s
00000000 ( 0%): Erasing
00004000 (66%): Erasing
Erased 24kB in 0.4s (60.0kB/s)
00000000 ( 0%): Programming
00004000 (66%): Programming
Programmed 18KB +6KB in 0.3s (80.0KB/s)
Verify failed at offset 0
Verify failed at offset 4000
Leaving target processor paused
//end
Who can help me resave it?Please!
    I program sof to EPCS4 first ,and then program *.elf to flash by NIOS_IDE_flash_programmer.
    Something wrong with me?
    First ,in a new project,I build a sopc_builder system,and add CPU,tristate_bridge,cfi_flash,sram and some PIOs.
    In nios_processor setting ,reset vector set as cfi_flash, offset set as 0x0
    ,then run Auto_assign_Base_address and Auto_assign_IRQs in System_view,
    last I generate the nios_system.
    After generate OK and assign Pins OK! I compile quartus_project!
    Then open the nios_ide,build software_project,set system_library_propetities,
    compile system.When does this OK,I program quartus_project first and then program elf to flash by NIOS_TOOL_FLASH_PROGRAMMER.
    Have you tried to run your program without using the flash?
    Just normally after programming hardware, launch Run as-> Nios II hardware.
    Does it work?
    Hi! I have the same problem!!
    cd G:/nios_ii_sw/led_blink_8bit/software/led_blink_8bit/Debug# Creating .flash file for the project
    "$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x02400000 --end=0x27fffff --reset=0x2400
    000 --input="led_blink_8bit.elf" --output="cfi_flash.flash" --boot="D:/altera/90
    /ip/altera/nios2_ip/altera_nios2/boot_loader_cfi.srec"# Programming flash with the project
    "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x02400000 --cable='USB-Blas
    ter [USB-0]' --sidp=0x02801010 --id=2017564571 --timestamp=1277911500 --instance
    Reading System ID at address 0x02801010: verified
    00004000 : Verifying existing contents
    00006000 : Verifying existing contents
    00008000 : Verifying existing contents
    Checksummed/read 46kB in 4.9s
    Erased 16kB in 0.5s (32.0kB/s)
    00004000 (25%): Programming
    00006000 (25%): Programming
    00008000 (25%): Programming
    Programmed 62KB in 0.9s (68.8KB/s)
    Verify failed at offset 6000
    Verify failed at offset 8000
    Have you solved this problem?
    My flash is set the 8bit databus connect to FPGA(EP2C5),when 16bit databus is no this problem.
    further more this problem usually appear when I compile the code and first download the .elf; when I download the same .elf to the flash in the secondtime ,it works.
    This is very strange!!
    The secondtime download ,it works:
    00000000 : Verifying existing contents
    Checksummed/read 16kB in 2.1s
    Erase not required
    00004000 ( 0%): Programming
    00006000 (12%): Programming
    Programmed 62KB in 2.5s (24.8KB/s)
    Device contents checksummed OK
    @shiy
    I also have the same problem ....Can you please me tell me how you solved the problem....
