14 years agomultiplexed display system
Dear Friends,
I am designing a multiplexed display system, I did the code without (as I think) errors but I got a syntax error messages as follows: library IEEE; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity multi_display_system is port ( rst, clk : in std_logic; d7s : out std_logic_vector (7 downto 0); An : out std_logic_vector (3 downto 0) ); end multi_display_system; architecture mixed of multi_display_system is signal addr_bin : std_logic_vector (3 downto 0); signal count_2b : std_logic_vector (1 downto 0); signal count : std_logic_vector (24 downto 0); signal slow_clk : std_logic; begin process (count_2b) begin case count_2b is when "00" => addr_bin <= "0000"; when "01" => addr_bin <= "1001"; when "10" => addr_bin <= "1010"; when "11" => addr_bin <= "1111"; when others => null; end case; end process; d7s <= "11000000" when addr_bin = "0000" else "11111001" when addr_bin = "0001" else "10100100" when addr_bin = "0010" else "10110000" when addr_bin = "0011" else "10011001" when addr_bin = "0100" else "10010010" when addr_bin = "0101" else "10000010" when addr_bin = "0110" else "11111000" when addr_bin = "0111" else "10000000" when addr_bin = "1000" else "10010000" when addr_bin = "1001" else "10001000" when addr_bin = "1010" else "10000011" when addr_bin = "1011" else "11000110" when addr_bin = "1100" else "10100001" when addr_bin = "1101" else "10000110" when addr_bin = "1110" else "10001110"; process (clk,count) begin if rising_edge (clk) then count <= count +1; end if; -- the frequency of slow_clk is 1.49 Hz for clk = 50 MHz (50 M / 2^16 Hz = 762.94) -- slow_clk <= count(15) ; -- display without flicker end process; process (rst, slow_clk) begin if rst = '1' then count_2b <= "00"; else if rising_edge (slow_clk) then count_2b <= count_2b +1; end if; end process; -- syntax error: expecting "if" process (count_2b) begin -- syntax error: expecting ":=", or "<=" case count_2b is when "00" => AN <= "1110"; -- Lights only display 0 when "01" => AN <= "1101"; -- Lights only display 0 when "10" => AN <= "1011"; -- Lights only display 0 when "11" => AN <= "0111"; -- Lights only display 0 when others => null; end case; end process; -- syntax error: expecting "if" end mixed;8 Replies
done, thank you very much
You still haven't changed the "else if" to "elsif".
With "else if", you in fact have two nested ifs in your code, that would require two "end if;" to properly close them. Using identation with tabs can show this:
orprocess (rst, slow_clk) if rst = '1' then count_2b <= "00"; else if rising_edge(slow_clk) then count_2b <= count_2b +1; end if; end if; end process;process (rst, slow_clk) if rst = '1' then count_2b <= "00"; elsif rising_edge(slow_clk) then count_2b <= count_2b +1; end if; end process; - Altera_Forum
TO_BE_DONE
TO_BE_DONE
--- Quote Start --- Ahh, my fault - try: rising_edge(clk) instead of rising_edge (clk) Sorry about that. I was trying to preserve your code format and didn't notice. --- Quote End --- I appreciate your effort to help me, thank you very much, now, the problem is the same. I put here the code after your guide: library IEEE; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity multi_display_system is port ( rst, clk : in std_logic; d7s : out std_logic_vector (7 downto 0); An : out std_logic_vector (3 downto 0) ); end multi_display_system; architecture mixed of multi_display_system is signal addr_bin : std_logic_vector (3 downto 0); signal count_2b : std_logic_vector (1 downto 0); signal count : std_logic_vector (24 downto 0); signal slow_clk : std_logic; begin process (count_2b) begin case count_2b is when "00" => addr_bin <= "0000"; when "01" => addr_bin <= "1001"; when "10" => addr_bin <= "1010"; when "11" => addr_bin <= "1111"; when others => null; end case; end process; d7s <= "11000000" when addr_bin = "0000" else "11111001" when addr_bin = "0001" else "10100100" when addr_bin = "0010" else "10110000" when addr_bin = "0011" else "10011001" when addr_bin = "0100" else "10010010" when addr_bin = "0101" else "10000010" when addr_bin = "0110" else "11111000" when addr_bin = "0111" else "10000000" when addr_bin = "1000" else "10010000" when addr_bin = "1001" else "10001000" when addr_bin = "1010" else "10000011" when addr_bin = "1011" else "11000110" when addr_bin = "1100" else "10100001" when addr_bin = "1101" else "10000110" when addr_bin = "1110" else "10001110"; process (clk,count) begin --rising_edge(clk) if rising_edge(clk) then count <= count +1; end if; -- the frequency of slow_clk is 1.49 Hz for clk = 50 MHz (50 M / 2^16 Hz = 762.94) -- slow_clk <= count(15) ; -- display without flicker end process; process (rst, slow_clk) begin if rst = '1' then count_2b <= "00"; else if rising_edge(slow_clk) then count_2b <= count_2b +1; end if; end process; process (count_2b) begin case count_2b is when "00" => AN <= "1110"; -- Lights only display 0 when "01" => AN <= "1101"; -- Lights only display 0 when "10" => AN <= "1011"; -- Lights only display 0 when "11" => AN <= "0111"; -- Lights only display 0 when others => null; end case; end process; end mixed; by the way: how do you put the code in this forum using a scrolling text box? - Altera_Forum
rising_edge(clk) instead of rising_edge (clk) Sorry about that. I was trying to preserve your code format and didn't notice. - Altera_Forum
thank you for your help,
before I see the Gated clocks and how should it be, I corrected the first problem as you said, but I got the following error in the same line of the correction (your mentioned) the error message is: Error (10500): VHDL syntax error at multi_display_system.vhd(59) near text "rising_edge"; expecting "(", or "'", or "." would you please show me your kind answer? thank you - Altera_Forum
Your problem is here:
else if rising_edge (slow_clk) then count_2b <= count_2b +1; it should be: elsif rising_edge (slow_clk) then count_2b <= count_2b +1; This should fix the first of your compile issues. (you have more, but I will leave you to them) Now that we have that fixed, I noticed you are using a gated clock. :evil: Gated clocks should be avoided if possible. Instead use clock enables. They look something like this:process (rst,clk) begin IF (rst = '1') THEN count =(OTHERS => '0'); slow_clock_enable_s <= '0'; ELSIF rising_edge(clk) THEN IF (count(15) = '1') THEN count =(OTHERS => '0'); slow_clock_enable_s <= '1'; ELSE count <= count +1; slow_clock_enable_s <= '0'; END IF; end if; end process; process (rst, clk) begin if rst = '1' then count_2b <= "00"; elsif rising_edge (clk) then IF (slow_clock_enable_s = '1') THEN count_2b <= count_2b +1; END IF; end if; end process;
