14 years agomultiplexed display system
Dear Friends, I am designing a multiplexed display system, I did the code without (as I think) errors but I got a syntax error messages as follows: library IEEE; use ieee.std_logic_1164.all...
14 years ago --- Quote Start --- Ahh, my fault - try: rising_edge(clk) instead of rising_edge (clk) Sorry about that. I was trying to preserve your code format and didn't notice. --- Quote End --- I appreciate your effort to help me, thank you very much, now, the problem is the same. I put here the code after your guide: library IEEE; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity multi_display_system is port ( rst, clk : in std_logic; d7s : out std_logic_vector (7 downto 0); An : out std_logic_vector (3 downto 0) ); end multi_display_system; architecture mixed of multi_display_system is signal addr_bin : std_logic_vector (3 downto 0); signal count_2b : std_logic_vector (1 downto 0); signal count : std_logic_vector (24 downto 0); signal slow_clk : std_logic; begin process (count_2b) begin case count_2b is when "00" => addr_bin <= "0000"; when "01" => addr_bin <= "1001"; when "10" => addr_bin <= "1010"; when "11" => addr_bin <= "1111"; when others => null; end case; end process; d7s <= "11000000" when addr_bin = "0000" else "11111001" when addr_bin = "0001" else "10100100" when addr_bin = "0010" else "10110000" when addr_bin = "0011" else "10011001" when addr_bin = "0100" else "10010010" when addr_bin = "0101" else "10000010" when addr_bin = "0110" else "11111000" when addr_bin = "0111" else "10000000" when addr_bin = "1000" else "10010000" when addr_bin = "1001" else "10001000" when addr_bin = "1010" else "10000011" when addr_bin = "1011" else "11000110" when addr_bin = "1100" else "10100001" when addr_bin = "1101" else "10000110" when addr_bin = "1110" else "10001110"; process (clk,count) begin --rising_edge(clk) if rising_edge(clk) then count <= count +1; end if; -- the frequency of slow_clk is 1.49 Hz for clk = 50 MHz (50 M / 2^16 Hz = 762.94) -- slow_clk <= count(15) ; -- display without flicker end process; process (rst, slow_clk) begin if rst = '1' then count_2b <= "00"; else if rising_edge(slow_clk) then count_2b <= count_2b +1; end if; end process; process (count_2b) begin case count_2b is when "00" => AN <= "1110"; -- Lights only display 0 when "01" => AN <= "1101"; -- Lights only display 0 when "10" => AN <= "1011"; -- Lights only display 0 when "11" => AN <= "0111"; -- Lights only display 0 when others => null; end case; end process; end mixed; by the way: how do you put the code in this forum using a scrolling text box?
