14 years agomultiplexed display system
Dear Friends, I am designing a multiplexed display system, I did the code without (as I think) errors but I got a syntax error messages as follows: library IEEE; use ieee.std_logic_1164.all...
14 years agoYou still haven't changed the "else if" to "elsif".
With "else if", you in fact have two nested ifs in your code, that would require two "end if;" to properly close them. Using identation with tabs can show this:process (rst, slow_clk)
if rst = '1' then
count_2b <= "00";
else
if rising_edge(slow_clk) then
count_2b <= count_2b +1;
end if;
end if;
end process;orprocess (rst, slow_clk)
if rst = '1' then
count_2b <= "00";
elsif rising_edge(slow_clk) then
end if;
end process;
