14 years agomultiplexed display system
Dear Friends, I am designing a multiplexed display system, I did the code without (as I think) errors but I got a syntax error messages as follows: library IEEE; use ieee.std_logic_1164.all...
14 years agothank you for your help,
before I see the Gated clocks and how should it be, I corrected the first problem as you said, but I got the following error in the same line of the correction (your mentioned) the error message is: Error (10500): VHDL syntax error at multi_display_system.vhd(59) near text "rising_edge"; expecting "(", or "'", or "." would you please show me your kind answer? thank you
