13 years ago
Multi IO voltage JTAG
My circuit is composed 4 Stratix4s per chain.
And each FPGA has multiple IO voltage. (see attachment picture)
Vccio of each FPGA's bank1A is connected to 2.5V.
So we connected pull-up to 2.5V.
But in my circuit there are no buffer or voltage translator.
i wonder my circuit conceptually is good for jtag operation without level translator.
JS Lee
    This issue is solved. The circuit has no problme. The problem was "Damaged FPGA". Thanks a lot.
    Hi FvM,
    Thank you for your reply.
    It's lucky.
    Anyway did you mean, even if other IO bank is connected different VCCIO, it is nothing to JTAG interface right ?
    Boundary cells are supplied from each VCCIO, so different IO bank might cause the error when signal shift to next cell.
    That's my concern.
    I want to clarify my concept.
    Thank you ~
    Your JTAG chain is apparently all-2.5V. Why should it need a level translator?
    Extensive JTAG chains might have problems with crosstalk of fast on-board to JTAG signals, particularly TCK. In this case, buffers can be helpful sometimes.
