griffin1701's avatar
griffin1701
1 year ago
More info needed regarding Schmitt Trigger input setting in Max-V CPLD
I am looking for the center voltage value for a pin on the Max V CPLD, when it is configured as a 3.3V Schmitt trigger input. The datasheet shows a hysteresis voltage of 400 mV for Vccio = 3.3V, but it does not specify that actual trip points, or at least the center point.
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    AqidAyman_Altera
    Thank you for the input, Frank.
    Do you have any more help needed on this issue?
  • griffin1701's avatar
    griffin1701
    Thanks for the info. We decided to perform the measurements ourselves, as you recommended.
  • FvM's avatar
    FvM
    unfortunately MAX V datasheet (neither other CPLD or FPFA datasheets) give typical threshold voltage for 3.3V IO-standard, you can assume that it's somewhere between Vil,max of 0.8 V and Vih,min of 1.7 V. 3.3V ST thresholds have in case of doubt +/- offset to lvcmos33.
    To evaluate typical ST thresholds, you'll need to make your own measurements. You can e.g. setup a slow RC ST oscillator and measure reversal points.
