griffin1701
1 year agoMore info needed regarding Schmitt Trigger input setting in Max-V CPLD
I am looking for the center voltage value for a pin on the Max V CPLD, when it is configured as a 3.3V Schmitt trigger input. The datasheet shows a hysteresis voltage of 400 mV for Vccio = 3.3V, but...
- 1 year ago
Thank you for the input, Frank.
Do you have any more help needed on this issue?
FvM
1 year agoHi,
unfortunately MAX V datasheet (neither other CPLD or FPFA datasheets) give typical threshold voltage for 3.3V IO-standard, you can assume that it's somewhere between Vil,max of 0.8 V and Vih,min of 1.7 V. 3.3V ST thresholds have in case of doubt +/- offset to lvcmos33.
To evaluate typical ST thresholds, you'll need to make your own measurements. You can e.g. setup a slow RC ST oscillator and measure reversal points.
