14 years ago
ModelSim vsim-3039 fatal error
Hi all,
I would like to simulate a very simple design in SystemVerilog and to compare the results of RTL and gate level simulation. The RTL simulation works OK but if I launch the gate level simulation the ModelSim reports:# ALTERA version supports only a single HDL# ** Fatal: (vsim-3039) D:/... failed.# FATAL ERROR while loading design# Error loading design# Error: Error loading design
Can anybody help me? Many thanks in advance.
    This is the valuable answer, I have changed settings to SystemVerilog and it is working OK.
    Thank you! Jaromir
    Modelsim-Altera only supports single-language compilation. Your example is compiling both VHDL and SystemVerilog.
    Change your project settings to generate a Verilog netlist (.vo) instead of VHDL netlist (.vho).
    Cheers,
    Dave
    Dave,
    I have launched the Fitter (Place & Route) in the Task pane of Quartus GUI, passed OK, then I launched EDA Netlist Writer, and then Tools => Run EDA Simulation Tool => EDA Gate Level Simulation..., all of the Quartus GUI. I believe the Quartus ensures proper setting of ModelSim, here is corresponding part of the ModelSim log - I guess it shows all necessary:
    # vcom -93 -work work {CombRepeater.vho}# Model Technology ModelSim ALTERA vcom 6.6d Compiler 2010.11 Nov 2 2010# -- Loading package standard# -- Loading package std_logic_1164# -- Loading package vital_timing# -- Loading package vital_primitives# -- Loading package cycloneiv_atom_pack# -- Loading package cycloneiv_components# -- Compiling entity combrepeater# -- Compiling architecture structure of combrepeater# # vlog -sv -work work +incdir+D:/1AlteraDsgn/Quart11/0SysVerilog/CombRepeater {D:/1AlteraDsgn/Quart11/0SysVerilog/CombRepeater/CombRepeaterTF.sv}# Model Technology ModelSim ALTERA vlog 6.6d Compiler 2010.11 Nov 2 2010# -- Compiling module CombRepeaterTF# # Top level modules:# CombRepeaterTF#
    The error message tells you the problem: Instantiation of 'CombRepeater' failed.
    Have you compiled the source for 'CombRepeater'?
    Cheers,
    Dave
    dwh,
    the full line in question is:
    # ** Fatal: (vsim-3039) D:/1AlteraDsgn/Quart11/0SysVerilog/CombRepeater/CombRepeaterTF.sv(5): Instantiation of 'CombRepeater' failed.
    It contains the path to my design, I considered it not important.
    Jaromir Kolouch
