12 years agoMixing IO standards on Arria V GX (LVDS / DDR3L SSTL-135)?
I am trying to assign FPGA pins for a new Arria V project. I use 4 hardware DDR3 controllers, 33 LVDS input pins and 1 LVDS output pin in this project. Quartus fitter compiled but it has mixed different IO standards (LVDS and SSTL-135/differential 1.35-V SSTL) in the same Vref groups and I am not sure that it can works. I don’t know much about Arria V family and its IO capabilities and I am wondering how do I need to supply FPGA power banks. If I supply my design with VCCPD=2.5V, VCCIO=1.35V and VREF=1.35V will it work? Is it possible to mix LVDS inputs and DDR3L IOs in a same Vref group ? Here are Fitter results: b3a_n0: Jtag pins: - 3 IN / 1 Out, IO standard=2.5V (non assignable pins) DDR3L pins: - 1 IN (ddr_rzq), IO standard SSTL-135 - Several Out, IO standard SSTL-135 - 1 Out (ddr_ck), differential 1.35V SSTL b7a_n0: LVDS: - Several LVDS IN DDR3L pins: - 1 IN (ddr_rzq), IO standard SSTL-135 b8a_n0: LVDS - Several LVDS IN DDR3L pins: - 1 IN (ddr_rzq), IO standard SSTL-135 - Several Out, IO standard SSTL-135 - 1 Out (ddr_ck), differential 1.35V SSTL Thanks in advance for helping. Environnement: Quartus 13.0sp1 FPGA Arria V GX 5AGXFA5H4F35C5 4x DDR3L 16bits modules1 Reply
I had a reply from altera support and the result is:
A bank supply with Vccpd=2.5V / Vccio=1.35V / Vref=0.675V can support: - LVDS inputs because it use Vccpd voltage only - SSTL-135 inputs and outputs because all 3 voltages are well set.
