9 years agoMegaWizard for 2-port RAM with registered write port and unregistered read port
Hi there, I want to generate a 2 port RAM using MegaWizard.
I need that the rdaddress and rdenable inputs without register them first, because this will cause a one clock cycle delay and the internal bus that I use expects that the result shows on the next rising edge of clock when rdaddress and rdenable is high. I also found that write port has to be registered no matter whether M20K or MLAB is used. Read port is different. If I use M20k, I can not choose "no registered" read port. If use MLAB I can. I wonder is that means I can not use M20K in my situation? Thanks for any comments!
