EEren's avatar
EEren
7 years ago
MAX10 RSU Project
I'm looking at MAX10 RSU Project - an example how to download a binary image file to CFM1/2.
There is following lines
case 9:	/*State 9: Start write into CFM1 with new image*/
for(address=CFM1StartAddress; address<=CFM1EndAddress; address=address+4)
     scanf("%2x%2x%2x%2x",&receivedHex[0],&receivedHex[1],&receivedHex[2],&receivedHex[3]); /*Get 4 bytes from UART Terminal*/
    for(byte=0; byte<4; byte++)
		receivedHex[byte] = (((receivedHex[byte] & 0xaa)>>1)|((receivedHex[byte] & 0x55)<<1));		/*Swap LSB with MSB before write into CFM*/
		receivedHex[byte] = (((receivedHex[byte] & 0xcc)>>2)|((receivedHex[byte] & 0x33)<<2));
		receivedHex[byte] = (((receivedHex[byte] & 0xf0)>>4)|((receivedHex[byte] & 0x0f)<<4));
	word = (receivedHex[0]<<24)|(receivedHex[1]<<16)|(receivedHex[2]<<8)|(receivedHex[3]);					/*Combine 4 bytes to become 1 word before write operation*/
	IOWR_32DIRECT(ONCHIP_FLASH_0_DATA_BASE, address, word);					/*Command to write into On-Chip Flash IP*/
and so on...
The first question - why the address incremented by 4 - for(address=CFM1StartAddress; address<=CFM1EndAddress; address=address+4) - every address holds 32 bits.
The second one - we get bytes from rpd file but lsb byte goes as msb byte in the address? word = (receivedHex[0]<<24)|(receivedHex[1]<<16)|(receivedHex[2]<<8)|(receivedHex[3]);
  • sstrell's avatar
    sstrell
    As mentioned, Avalon masters use byte addressing and Avalon slaves use word addressing. The word size is typically the data width (32 in this case). So Avalon masters access the registers/memory locations for a slave at addresses 0x0, 0x4, 0x8, etc. For a 16 bit slave, the master would access the slave at 0x0, 0x2, 0x4, etc., though if the master itself is 32-bit, it would only need to access at 0x0, 0x4, etc. and could use byte enables for the appropriate bytes/words. See the Avalon spec for details:
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_avalon_spec.pdf
    Also check out online training:
    https://www.intel.com/content/www/us/en/programmable/support/training/course/oqsys3000.html
    #iwork4intel
  • JohnT_Altera's avatar
    JohnT_Altera
    If you are refering to Avalon-MM Slave then it is addition by 1 on each avmm_data_addr or avmm_csr_addr.
  • EEren's avatar
    EEren
    Why byte addressing? It says we writes words in ug-m10-ufm-16.0.pdf, so we create a word word = (receivedHex[0]<<24)|(receivedHex[1]<<16)|(receivedHex[2]<<8)|(receivedHex[3]); then write it to a specific address and then what? skip 4 addresses?
    When I generate FLASH UPDATE IP in QSYS
    component flash_update is
    port (
    clock : in std_logic := '0'; -- clk.clk
    avmm_csr_addr : in std_logic := '0'; -- csr.address
    avmm_csr_read : in std_logic := '0'; -- .read
    avmm_csr_writedata : in std_logic_vector(31 downto 0) := (others => '0'); -- .writedata
    avmm_csr_write : in std_logic := '0'; -- .write
    avmm_csr_readdata : out std_logic_vector(31 downto 0); -- .readdata
    avmm_data_addr : in std_logic_vector(18 downto 0) := (others => '0'); -- data.address
    avmm_data_read : in std_logic := '0'; -- .read
    avmm_data_writedata : in std_logic_vector(31 downto 0) := (others => '0'); -- .writedata
    avmm_data_write : in std_logic := '0'; -- .write
    avmm_data_readdata : out std_logic_vector(31 downto 0); -- .readdata
    avmm_data_waitrequest : out std_logic; -- .waitrequest
    avmm_data_readdatavalid : out std_logic; -- .readdatavalid
    avmm_data_burstcount : in std_logic_vector(3 downto 0) := (others => '0'); -- .burstcount
    reset_n : in std_logic := '0' -- nreset.reset_n
    end component;
    as we can see data bus 32-bit and on every write I should increment avmm_data_addr by one as I understand.
    When I create Altera On-Chip Flash IP I get the following addresses
    sector 3 - 0x10000 - 0x6FFFF
    sector 4 - 0x70000 - 0xB7FFF
    sector 5 - 0xB8000 - 0x15FFFF
    But when I Generate HDL
    SECTOR3_START_ADDR => 16384,
    SECTOR3_END_ADDR => 114687,
    SECTOR4_START_ADDR => 114688,
    SECTOR4_END_ADDR => 188415,
    SECTOR5_START_ADDR => 188416,
    SECTOR5_END_ADDR => 360447,
    So it's already divided by 4. Isn't it?
    JohnT_Altera
    Avalon Master is using byte addressing so that it can handle different data width from 8bit to 64bit data.
    The default rpd file generated is in little endian format while the On Chip Memory need Big Endian format. So if you are using little endian format rpd file then you will need to performed endian swap.
