MAX10 RSU Project
Why byte addressing? It says we writes words in ug-m10-ufm-16.0.pdf, so we create a word word = (receivedHex[0]<<24)|(receivedHex[1]<<16)|(receivedHex[2]<<8)|(receivedHex[3]); then write it to a specific address and then what? skip 4 addresses?
When I generate FLASH UPDATE IP in QSYS
component flash_update is
port (
clock : in std_logic := '0'; -- clk.clk
avmm_csr_addr : in std_logic := '0'; -- csr.address
avmm_csr_read : in std_logic := '0'; -- .read
avmm_csr_writedata : in std_logic_vector(31 downto 0) := (others => '0'); -- .writedata
avmm_csr_write : in std_logic := '0'; -- .write
avmm_csr_readdata : out std_logic_vector(31 downto 0); -- .readdata
avmm_data_addr : in std_logic_vector(18 downto 0) := (others => '0'); -- data.address
avmm_data_read : in std_logic := '0'; -- .read
avmm_data_writedata : in std_logic_vector(31 downto 0) := (others => '0'); -- .writedata
avmm_data_write : in std_logic := '0'; -- .write
avmm_data_readdata : out std_logic_vector(31 downto 0); -- .readdata
avmm_data_waitrequest : out std_logic; -- .waitrequest
avmm_data_readdatavalid : out std_logic; -- .readdatavalid
avmm_data_burstcount : in std_logic_vector(3 downto 0) := (others => '0'); -- .burstcount
reset_n : in std_logic := '0' -- nreset.reset_n
end component;
as we can see data bus 32-bit and on every write I should increment avmm_data_addr by one as I understand.
When I create Altera On-Chip Flash IP I get the following addresses
sector 3 - 0x10000 - 0x6FFFF
sector 4 - 0x70000 - 0xB7FFF
sector 5 - 0xB8000 - 0x15FFFF
But when I Generate HDL
SECTOR3_START_ADDR => 16384,
SECTOR3_END_ADDR => 114687,
SECTOR4_START_ADDR => 114688,
SECTOR4_END_ADDR => 188415,
SECTOR5_START_ADDR => 188416,
SECTOR5_END_ADDR => 360447,
So it's already divided by 4. Isn't it?
