8 years ago
MAX10 PLL External Clock Output
Hello there,
I'm using the 10M08SCE144A7G FPGA.
In my design I need to give a clk input signal to 3 diferents Analog to Digital Converters. I'm thinking of using a PLL External Clock Output (signal PLL_L_CLKOUTp of the FPGA) to give the clock to these 3 converters.
There is only 1 output of this type with this FPGA.
I'll like to know if there is any recommendations using this output signal to fed 3 diferents Analog to Digital Converters ? (fanout , layout for exemple)
Is this a good way to do it ?
Maybe driving the PLL output to 3 diferents standard fast I/O pins (1 pin for 1 DAC) is a better design ?
Thank you for your help.
Julien.
    Is it a high frequency clock? If it's not too high it shouldn't be a problem to output the clock on a regular I/O instead of a dedicated PLL output. It is just a bit slower.
    If you have problems meeting timing constraints with that solution, you can also use a DDS output, clocked with the PLL clock you want to export, and with the two SDR inputs set to 0 and 1. It will generate a signal with the same frequency, and usually a shorter delay than when connecting the clock directly to the I/O pin.
    If possible I'd recommend that you build a (at least) minimal Quartus project with your timing requirements and verify that you can meet them before committing the pins assignments on the PCB layout.
    Hi JDL,
    The MAX 10 PLLs can drive out to any regular I/O pin through the GCLK. You can refer to the MAX10 PLL user guide:
    https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/max-10/ug_m10_clkpll.pdf
    Each PLL generates five clock outputs through the c[4..0] counters. Even though only the C0 output counter can feed to the dedicated external clock outputs without going through the GCLK, other output counters can feed other I/O pins through the GCLK. So you should be able to feed the PLL output to I/O pins.
    nyusof
