MAX10 FPGA pof-file programming fails
Hi all, I build a custom 10M02SCM153 board, when I attempt to download the .pof file, I got "Error (209012): Operation failed" at 4%. However, I can .sof can be loaded. Could anyone provide some hints to debug it?
Thanks in advance.
Linfeng
- Farabi_Altera
Please raise new forum case to get support. I will close this old thread.
regards,
Farabi
- NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
- llbb
Any updates about error at 4%?
- NurAiman_M_Intel
Have you try the suggestion from our friends? Any update?
Aiman
- GLees
Contributor
Just a heads-up, and this may have nothing to do with your problem, but the MAX10 has a bug when programming .pof. All the pins are supposed to be floating during configuration, but some get configured as outputs and may contend with chips on the board that are trying to drive those pins. This can cause high current and weird problems. There is a way to get around it by selecting a particular programming option, but I forget what that is at the moment.
- fadil-iwave
I have also faced a similar issue regarding the .pof file programming on the MAX10 FPGA. It doesn't program upto 4% but fails immediately even though the .sof file of the same design is flashing successfully. Have you come across this issue and fixed it. If so, do you remember what that workaround programming option is?
- FvM
did you try with programmer option "Halt on-chip configuration controller"?
It may be also the case that your board hardware is trying to reconfigure the FPGA.Regards
Frank
