max10 compile warning ID=169202 inconsistent VCCIO across multiple banks of configuration pins >> How to solve this ?
Dear,
10M08SCU169I7G with vccio1B=1.8v; vccio8=3.3V (vccio1a=2.5v)Configuration pins are in banks 1B + 8
Quartus prime 18.0 standard build 614
Warning (169202): Inconsistent VCCIO across multiple banks of configuration pins. The configuration pins are contained in 2 banks in 'Internal Configuration' configuration scheme and there are 2 different VCCIOs.
Stefan
- brivals
This problem is still present in Quartus 23.1std.1 Build 993 SC Standard Edition.Regards,
Barbara
- ShafiqY_Intel
Hi Stefan,
The problem of this warning ID because the configuration pins are powered by different Vccio in different banks.
Solution: Enforce a configuration voltage level in the Configuration tab
Cheers
- SVran
Hello Shafiq,
Pin-planner signal list shows vccio1b=1.8 and vccio8=3.3 because I defined these io-standards on their signals in assignment-editor.
assignments > device > device and pin options > configuration : in this screen I tried with box checked/unchecked "Force Vccio to be compatible with configuration IO-voltage: but this gives no difference .... I don't see anything else I that relates to Vccio 0 config pins ? ?
Stefan
- ShafiqY_Intel
Hi Stefan,
The issue has not been solved in Quartus 19.1 standard.
This warning will be remove in a future release of the Quartus standard
I'm apologize for inconvenience.
