max10 compile warning ID=169202 inconsistent VCCIO across multiple banks of configuration pins >> How to solve this ?
Hi Stefan,
The problem of this warning ID because the configuration pins are powered by different Vccio in different banks.
Solution: Enforce a configuration voltage level in the Configuration tab
Cheers
Hello Shafiq,
Pin-planner signal list shows vccio1b=1.8 and vccio8=3.3 because I defined these io-standards on their signals in assignment-editor.
assignments > device > device and pin options > configuration : in this screen I tried with box checked/unchecked "Force Vccio to be compatible with configuration IO-voltage: but this gives no difference .... I don't see anything else I that relates to Vccio 0 config pins ? ?
Stefan
- ShafiqY_Intel6 years ago
Hi Stefan,
The issue has not been solved in Quartus 19.1 standard.
This warning will be remove in a future release of the Quartus standard
I'm apologize for inconvenience.
- SVran6 years ago
Hello Shafiq, ok issue clarified. I understand this is a false warning and it will be solved in a future Quartus release. By the way I also tried with Quartus19.1 standard edition but false warning is still there.
Regards, Stefan
Hi Stefan,
I'm apologize to take so much time to get the confirmation regarding to this issue. I tested on my side and get the further confirmation from my colleague.
The rule of thumb: The VCCIO for bank 1B (bank 1 for 10M02 devices) and bank 8 must be powered up to a voltage between 1.5V – 3.3V during configuration.
Thus, as long as your Bank 1B & Bank 8 is powered up between that range, you are allowed to have different voltage or same voltage.
When I did the duplication on my side, I also got the same warning as yours:
Actually the warning that you get[Warning (169202)], is the false warning from Quartus. Quartus software Team will fixed it this false warning in future Quartus release.
You may refer to this KDB:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2018/-warning--169202---inconsistent-vccio-across-multiple-banks-of-c.html?wapkw=warning%20169202
- SVran6 years ago
Hello shafiq, PCB-layout is ongoing and I need to be sure that Vccio-1b and Vccio-8 do NOT need to be the same volage. Why should banks 1b and 8 need to have the same voltage as they have different Vccio-pins ? Vccio-1b = 1.8V because jtag pins are wired to a 1.8V powered device. Vccio-8 = 3.3V because bank8 pins are wired to 3.3V devices Changing this will impact my design and pcb-layout. Either can you confirm that Vccio-1b and Vccio-8 are allowed to be different voltage ? Or tell me how to suppress this warning ID=169202 ? Regards, Stefan - ShafiqY_Intel6 years ago
Hi Stefan,
The issue is the configuration pins are powered by different Vccio.
Have you tried use the same voltage for I/O bank 1B and I/O bank 8? If yes, is it able to solve the issue?
