7 years ago
MAX10 and Flash Update module
I created Flash Update module with Qsys
    onchip_flash_0 : component altera_onchip_flash
        generic map (
            INIT_FILENAME                       => "",
            INIT_FILENAME_SIM                   => "",
            DEVICE_FAMILY                       => "MAX 10",
            PART_NAME                           => "10M50DAF484C7G",
            DEVICE_ID                           => "50",
            SECTOR1_START_ADDR                  => 0,
            SECTOR1_END_ADDR                    => 8191,
            SECTOR2_START_ADDR                  => 8192,
            SECTOR2_END_ADDR                    => 16383,
            SECTOR3_START_ADDR                  => 16384,
            SECTOR3_END_ADDR                    => 114687,
            SECTOR4_START_ADDR                  => 114688,
            SECTOR4_END_ADDR                    => 188415,
            SECTOR5_START_ADDR                  => 188416,
            SECTOR5_END_ADDR                    => 360447,
            MIN_VALID_ADDR                      => 0,
            MAX_VALID_ADDR                      => 360447,
            MIN_UFM_VALID_ADDR                  => 0,
            MAX_UFM_VALID_ADDR                  => 16383,
            SECTOR1_MAP                         => 1,
            SECTOR2_MAP                         => 2,
            SECTOR3_MAP                         => 3,
            SECTOR4_MAP                         => 4,
            SECTOR5_MAP                         => 5,
            ADDR_RANGE1_END_ADDR                => 360447,
            ADDR_RANGE1_OFFSET                  => 2048,
            ADDR_RANGE2_OFFSET                  => 0,
            AVMM_DATA_ADDR_WIDTH                => 19,
            AVMM_DATA_DATA_WIDTH                => 32,
            AVMM_DATA_BURSTCOUNT_WIDTH          => 4,
            SECTOR_READ_PROTECTION_MODE         => 0,
            FLASH_SEQ_READ_DATA_COUNT           => 4,
            FLASH_ADDR_ALIGNMENT_BITS           => 2,
            FLASH_READ_CYCLE_MAX_INDEX          => 5,
            FLASH_RESET_CYCLE_MAX_INDEX         => 7,
            FLASH_BUSY_TIMEOUT_CYCLE_MAX_INDEX  => 36,
            FLASH_ERASE_TIMEOUT_CYCLE_MAX_INDEX => 10500000,
            FLASH_WRITE_TIMEOUT_CYCLE_MAX_INDEX => 9150,
            PARALLEL_MODE                       => true,
            READ_AND_WRITE_MODE                 => true,
            WRAPPING_BURST_MODE                 => false,
            IS_DUAL_BOOT                        => "False",
            IS_ERAM_SKIP                        => "True",
            IS_COMPRESSED_IMAGE                 => "True"
        port map (
            clock                   => clock,                   --    clk.clk
            reset_n                 => reset_n,                 -- nreset.reset_n
            avmm_data_addr          => avmm_data_addr,          --   data.address
            avmm_data_read          => avmm_data_read,          --       .read
            avmm_data_writedata     => avmm_data_writedata,     --       .writedata
            avmm_data_write         => avmm_data_write,         --       .write
            avmm_data_readdata      => avmm_data_readdata,      --       .readdata
            avmm_data_waitrequest   => avmm_data_waitrequest,   --       .waitrequest
            avmm_data_readdatavalid => avmm_data_readdatavalid, --       .readdatavalid
            avmm_data_burstcount    => avmm_data_burstcount,    --       .burstcount
            avmm_csr_addr           => avmm_csr_addr,           --    csr.address
            avmm_csr_read           => avmm_csr_read,           --       .read
            avmm_csr_writedata      => avmm_csr_writedata,      --       .writedata
            avmm_csr_write          => avmm_csr_write,          --       .write
            avmm_csr_readdata       => avmm_csr_readdata        --       .readdata
In oreder to have two images - bootloader(CFM0) and main program(CFM1-CFM2) - I need Dual Compressed Images.
So I set - Assignments -> Device -> Devise and Pin Options -> Configuration -> Dual Compressed Images
And generics in Flash Update module I set
IS_DUAL_BOOT        => "True",
When I compile I get an error
--- Quote Start ---
Error (169130): Configuration mode specified as Remote but remote update block is not found in design
--- Quote End ---
If I set Assignments -> Device -> Devise and Pin Options -> Configuration -> Single Compressed Image
And generics
It compiles without error.
And generics
I get an error
--- Quote Start ---
Error (14740): Configuration mode on atom "bootloader:U_BOOTLOADER|flash_update:U_FLASH_UPDATE|altera_onchip_flash : nchip_flash_0|altera_onchip_flash_block:altera_onchip_flash_block|ufm_block" does not match the project setting. Update and regenerate the Qsys system to match the project setting.
--- Quote End ---
How can I compile for Dual Compressed Images?
    --- Quote Start ---
    Look at the end of the document. The IP and its addressable locations are described.
    --- Quote End ---
    Sorry. I failed to understand what is it - Altera Dual Confguration IP Core Avalon-MM Address Map at the end of the document.
    There are 3 columns in the table - Offset, R/W,Width. Offset of what? What all this obscure ciphers?
    I have the following signals in this module
    avmm_rcv_address[2..0]
    avmm_rcv_read
    avmm_rcv_writedata[31..0]
    avmm_rcv_write
    avmm_rcv_readdata[31..0]
    How should I use it? Why should I seek an answer for a month? Where is a simple and clear explanation?
    for example - for Altera On-Chip Flash IP there is a document explaining all ports and pins and diagrams for all operations - all clear.
    what with this core? why should I have all this voodoo dances?
    --- Quote Start ---
    Address offset from the base address when you access the component.
    If you're not familiar with using Intel FPGA IP or Platform Designer (formerly known as Qsys), I'd suggest searching for documentation and training on the Avalon interface and the use of Platform Designer.
    Start with the Avalon spec:
    https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/mnl_avalon_spec.pdf
    --- Quote End ---
    I've created the component with Qsys - there is no base address. Any way it makes no sense - offsets in the table don't correlate with actual ports I have in the module.
    If you've looked at the training on RSU and the documentation, I'm not sure why you're still having an issue. The IP has an Avalon slave interface. You set a base address in Qsys (Platform Designer) so that a master component, such as Nios, can access and control it at a certain location in that master's address map. At the base address (offset 0), you access the control bits located in the first row of table 34 in the document I linked to. You adjust the address above the base address to access the other bits (default is increase address by 4 on the master to get to the next 32 bits (the second word) of the slave).
    Again, if none of this makes sense, you should read and learn the Avalon spec and about basic addressing in Platform Designer.
