8 years agoMAX10 and Flash Update module
I created Flash Update module with Qsys
onchip_flash_0 : component altera_onchip_flash
generic map (
INIT_FILENAME => "",
INIT_FILENAME...
8 years agoAddress offset from the base address when you access the component.
If you're not familiar with using Intel FPGA IP or Platform Designer (formerly known as Qsys), I'd suggest searching for documentation and training on the Avalon interface and the use of Platform Designer. Start with the Avalon spec: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/mnl_avalon_spec.pdf
