8 years agoMAX10 and Flash Update module
I created Flash Update module with Qsys
onchip_flash_0 : component altera_onchip_flash
generic map (
INIT_FILENAME => "",
INIT_FILENAME...
8 years ago --- Quote Start --- Look at the end of the document. The IP and its addressable locations are described. --- Quote End --- Sorry. I failed to understand what is it - Altera Dual Confguration IP Core Avalon-MM Address Map at the end of the document. There are 3 columns in the table - Offset, R/W,Width. Offset of what? What all this obscure ciphers? I have the following signals in this module avmm_rcv_address[2..0] avmm_rcv_read avmm_rcv_writedata[31..0] avmm_rcv_write avmm_rcv_readdata[31..0] How should I use it? Why should I seek an answer for a month? Where is a simple and clear explanation? for example - for Altera On-Chip Flash IP there is a document explaining all ports and pins and diagrams for all operations - all clear. what with this core? why should I have all this voodoo dances?
