pyreneos's avatar
pyreneos
7 days ago
MAX10 ADC Problem BANK 1A 1B 8
I have used a max10 chip and quartus 18 for the project. I have encourtered with ADC critical warning (16248). How can I solve this problem. For Bank 1B I can move the pins to other locations but the BANK 8 is vague because it lets some of the pins can be used. However it does not say which pins to be used properly.
I have researched about this topic and I have found this source.
https://docs.altera.com/r/docs/683751/25.1/max-10-general-purpose-i/o-user-guide/guidelines-analog-to-digital-converter-i/o-restriction
Is there other resources that could explain this problem and the solution? what should I do?
1 Reply
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    Can you provide the full part number of the MAX10 device you are using?
    Aqid
