Anandhu's avatar
Anandhu
Icon for New Member rankNew Member
3 hours ago
MAX 10 FPGA Programming Failure via JTAG – nSTATUS & CONFIG_DONE as No Connect
Title: MAX 10 FPGA Programming Failure via JTAG – nSTATUS & CONFIG_DONE as No Connect
Hello Community,
I am unable to program my Intel MAX 10 (10M08SAU169C8G) via JTAG using USB Blaster on Quartus Prime 24.1 (Windows 11).
HARDWARE CONFIGURATION:
• nCONFIG → Pulled HIGH to VCCIO
• nSTATUS → No Connect
• CONFIG_DONE → No Connect
• CONFIG_SEL → No Connect
WHAT I TRIED:
• Unchecked "Enable nCONFIG, nSTATUS, and CONF_DONE pins" in Device Pin Options
• Unchecked "Enable CONFIG_SEL pin" and "Auto-restart after error"
• Recompiled and reprogrammed
• USB Blaster recognized ✅
• MAX 10 detected in JTAG chain ✅
• Correct .SOF file selected ✅
Despite all this, programming still fails.
QUESTIONS:
1. Are NC config pins the root cause even in JTAG mode?
2. Is there a Quartus workaround without a PCB re-spin?
3. Recommended pull-up values for nSTATUS and CONFIG_DONE?
Any help is appreciated. Happy to share schematics or screenshots.
Thank you!
