avib's avatar
avib
3 hours ago
MAX 10 DA vs DD devices, can the same programming file be used?
We are considering using both DA and DD variants of the MAX 10, for example 10M50DAF484 and 10M50DDF484.
According to the device ordering information, the DD option adds Flash Access Control compared with the DA option.
Could you please clarify the following:
  1. Can the same Quartus-generated .pof programming file be used to program both the DA and DD devices, assuming the density, package, speed grade, and FPGA design are otherwise identical?
  2. Or must the Quartus project target the exact DA/DD device and generate a separate .pof for each OPN?
  3. If separate files are required, what is different in the generated programming data?
  4. Does the answer change if we are not using the DD Flash Access Control feature?
Our goal is to determine whether DA and DD devices can be used interchangeably in production without maintaining separate FPGA programming files.
Thank you
1 Reply
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
