14 years agomapping a port to several signals
Hi all!
I have got an issue, I don't really know if it's a bug from ModelSi or an error from my code. Maybe soeone will be able to tell me... A/° I am using: --- Quote Start --- ModelSim DE 6.6a Revision: 2010.03 Date: Mar 19 2010 --- Quote End --- B/° This code works:library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity test is
end entity test;
architecture behavioural of test is
component foo
port
s : out std_logic_vector(31 downto 0)
end component foo;
constant K : natural range 1 to 31 := 15;
signal msb : std_logic_vector(31 downto K);
signal lsb : std_logic_vector((K - 1) downto 0);
begin
foo_inst : foo
port map
s(31 downto K) => msb,
s((K - 1) downto 0) => lsb
end architecture behavioural; --- Quote Start --- ModelSim> vcom -reportprogress 300 -work work /home/reinauld/Bureau/test.vhd # Model Technology ModelSim DE vcom 6.6a Compiler 2010.03 Mar 19 2010 # -- Loading package standard # -- Loading package std_logic_1164 # -- Loading package numeric_std # -- Compiling entity test # -- Compiling architecture behavioural of test ModelSim> --- Quote End --- C/° I tried to replace the constant K with e generic that I can set when starting the simulation, but it does not work library ieee;
entity test is
generic
end entity test;
component foo
port
end component foo;
begin
foo_inst : foo
port map
end architecture behavioural; --- Quote Start --- ModelSim> vcom -reportprogress 300 -work work /home/reinauld/Bureau/test.vhd # Model Technology ModelSim DE vcom 6.6a Compiler 2010.03 Mar 19 2010 # -- Loading package standard # -- Loading package std_logic_1164 # -- Loading package numeric_std # -- Compiling entity test # -- Compiling architecture behavioural of test # ** Error: /home/reinauld/Bureau/test.vhd(29): (vcom-1024) Individually associated formal "s" must be identified with a locally static name. # ** Error: /home/reinauld/Bureau/test.vhd(30): (vcom-1024) Individually associated formal "s" must be identified with a locally static name. # ** Error: /home/reinauld/Bureau/test.vhd(30): (vcom-1048) Non-locally static choice (association# 2, choice# 1) is allowed only if it is the only choice of the only association. # ** Error: /home/reinauld/Bureau/test.vhd(33): VHDL Compiler exiting # /opt/modelsim_de/modelsim_dlx/linuxpe/vcom failed. ModelSim> --- Quote End --- Can anyone comment this? Maybe suggest another way to achieve what I try to do? The point is to map output of a signal driver (that reads stimuli from a file) to several stimuli signals. Thanks, Julien
